Originally Posted by chrislad Just got one yesterday.
1) What are the best apps out there? Have a couple but I'm sure I'm only seeing snapshots and forums are the best way to get ideas!!
2) Themes. Any decent ones out there? Would love a good Fallout 3 Pipboy one!!
3) Suggestions? Anything that helps with the setup, phone use etc? Should I get used to the trackball? Haven't touched it yet, since I'm use to an iPhone. |
1) There are loads of threads on this, it really depends on what you want tbh. A few that will crop up alot are:
Handcent - alternative sms client
Tracks - app to track your route e.g. training
ShopSavvy - barcode scanner which lets you see the price of something online
SMSBackup - a great app which backs up your sms messages to your gmail
Layar - augmented reality app - uses your camera and location to display additional information about your environment.
Simple advice is if you can think of an app you might want go and search the marketplace and you'll probably find it and it'll probably be free too.
3)If you haven't already flash the latest firmware this improves the ui performance - not sure what else, have a look at the settings and if you're not sure what a setting is for google it.
