| Re: Phone book (contacts) advice - Hero.
Should be perfectly feasible. I haven't synced with google, only outlook, but in theory it should be the same:
Sync the contacts to google, edit them on a pc, resync and bingo. it's done. You may need to look at the conflict settings (i.e. set which wins if the phone and google are different) but it should be a pretty easy process.
If there are any complications you could delete all from the phone after syncing to google, that way when you sync back you are sure to avoid any conflict or duplicate errors.
