| Re: Hero screen lock when on a call
That's odd, I'm pretty sure when a call ends on mine it unlocks itself and goes back to the "Phone" menu (where your recently dialled numbers are listed).
Also, to bring the screen back at any time during a call you can press the menu key. To begin with I cancelled a few calls by pressing the unlock key, forgetting that it's also the end call key!
Saying that, you shouldn't need to do that if your timeout is set to Never. Maybe that's the problem? Have you tried the other timeout options?
