Acer Aspire Revo Owners Thread
Thread Closed
Old 17-05-2009, 8:14 AM   #1
8,018, Level: 21
Points: 8,018, Level: 21 Points: 8,018, Level: 21 Points: 8,018, Level: 21
Thanks: Gave 25, Got 29
Hi all,
Right I didn't see anyone else answering questions so as a new owner I thought I would get the ball rolling.
I have the £249 version with 160gb hdd, this was purchased for one purpose, windows center, no gaming and no other apps.
The standard vista install is ok in media center but is not tv pack so the first thing I did was install the windows 7 RC from a bootable USB drive, can't post the guide is used right now as I'm typing this on my iPhone, it installed all drivers except coprocessor but that doesn't seem to affect anything.
Now to the burning questions, performance as a htpc:
I installed the divx mkv preview program and mkv's both 1080p and 720p play using no more than 20% CPU, better than I expected, and this was the only unanswered question I had seen in other reviews and previews, so yes hardware acceleration works on mkv files.
I have mine fitted the my monitor using the supplied bracket, this is so much better in the flesh, you have to see the quality, despite what the reviews say I have yet to really hear the fan so as a htpc this is awsome.
One critism is that ebuyer and indeed the acer Uk site list draft n wireless but this only has b and g unless I have a driver issue?
Also it's only 100mb Ethernet which is a shame but I can live with that.
Just reformatting my laptop so any question I will answer later.
Old 17-05-2009, 8:44 AM   #2
6,718, Level: 19
Points: 6,718, Level: 19 Points: 6,718, Level: 19 Points: 6,718, Level: 19
Thanks: Gave 180, Got 137
Re: Acer Aspire Revo Owners Thread
is the audio output one of those "secret spdif" ones? my laptops headphone port was actually an optical port too.
any chance this has that too?
Old 17-05-2009, 10:21 AM   #3
3,373, Level: 13
Points: 3,373, Level: 13 Points: 3,373, Level: 13 Points: 3,373, Level: 13
Thanks: Gave 4, Got 11
I've been spending a couple of hours looking at this kit this morning, though I'm thinking of the £150 1gb linux version. You state that Ethernet runs at 100mb only - what does that mean in practice for usage etc?
Old 17-05-2009, 11:28 AM   #4
8,018, Level: 21
Multi channel audio is only through hdmi, regaring 100 mb I can't see it being a problem as it's unlikley you would be transfering lots of files to this as it is a perfect home server client.
I have this in the bedroom and use dvblink to get tv of my sat dreambox, it's like having a native tuner.
Old 17-05-2009, 11:42 AM   #5
3,373, Level: 13
Thanks for the reply there, Gino. In terms of web surfing and general browsing, how does this unit play out? I appreciate that I'm looking at a different model to your own, but suspect that, allowing for Vista's higher CPU demands relative to Linux, that the two might be somewhat comparable. Reading around, I see that there are issues relating to Flash-enabled playback on YouTube (not essential for me), but that video media playback is excellent. Also, how about other programs (possibly MSOffice, if you have it?) etc.
Old 17-05-2009, 1:16 PM   #6
8,018, Level: 21
I'm only using media center but the performance when downloading and installing software was pretty slow.
I wouldn't recomend as a desktop replacment but media center is amazing on it, problem I have is no sound on dts mkv's?
Got dd mkv's working after installing latest realtek hd drivers, the default windows 7 drivers didn't work.
I installed ac3filter but still no joy, performance in general as a media center has surpassed my expectations, I really didn't expect such Stella performance.
Old 17-05-2009, 4:32 PM   #7
3,373, Level: 13
Hi, dts sound will depend on whether your tv has a built-in dts decoder most don't, although dd seems more like standard, assuming you're passing the signal via hdmi straight through to your tv set - or are you going via an amp?
ginoworm (17-05-2009)
Old 17-05-2009, 4:57 PM   #8
1,722, Level: 9
Points: 1,722, Level: 9 Points: 1,722, Level: 9 Points: 1,722, Level: 9
Did the revo come with a driver disc for xp/vista? I could find them on the Acer site.
Old 17-05-2009, 5:40 PM   #9
8,018, Level: 21
DTS working now, i didnt enable the directshow filterwhen i installed ac3filter, i think that was it.
No didnt come with a disk, has a recovery partition which i have left untouched, on the acer site it only has Audio, chipset and wifi drivers, its under the model number R3600 not revo.
going to install fresh new build later (7126), ive been messing so much trying to get Audio so wont hurt.
Still very much impressed.
Old 17-05-2009, 6:00 PM   #10
1,722, Level: 9
Cheers i'll d/l the drivers, Just ordered my Revo off play.com, gonna use it as a CCTV DVR instead of my my EEE 4G.
Old 18-05-2009, 8:28 AM   #11
NaTT's Avatar
1,076, Level: 7
Points: 1,076, Level: 7 Points: 1,076, Level: 7 Points: 1,076, Level: 7
Thanks: Gave 43, Got 29
Originally Posted by ginoworm View Post
Hi all,
good news (I'm hoping my linux version arrives today from Play, but the status doesn't look promising...) but I can't help but think your statement might be based on an incomplete set of scenarios. I hope not, I'd love to be proven wrong...
MKVs can "contain" many variations on the theme "1080p" and depending on how they were encoded and what was encoded will determine if hardware acceleration is possible.
I've a lot of 1080p MKVs that refuse to be accelerated and the ones I've made with full resolution Flac audio files always bump up the CPU usage.
Have you any MKVs that you'd not been able to H/A before, but now can?
With the Atom processor, I fear that if you can't H/A a high bit rate file, you won't get watchable results. In which case it'll become an electricity saving Download device for me and not the HCPC replacement I'm hoping for.
Old 18-05-2009, 2:51 PM   #12
3,373, Level: 13
Does anyone know which particular version of Linux it ships with? NaTT, I'd be really interested in a review if you find the time to post one, with details regarding web browsing and office apps, if possible. I'm thinking of maybe picking up an extra Gb of Ram to help the thing along.
Old 18-05-2009, 3:43 PM   #13
palfret
Posts: n/a
Post Re: Acer Aspire Revo Owners Thread
I'm interested in getting one of these, but was wondering which WiFi chipset they're using? I'm planning on building a device that can act as a WiFi access point, and that's only supported by some of the Linux WiFi drivers (notably, *not* the ndiswrapper ones for example). Obviously I could stick a suitable WiFi/USB device in instead, but I'd rather if it works with the internal device, but I can't seem to find any details anywhere on what WiFi device they've used.
Obviously, this is mainly for the Linux models, but curious to see if they put the same device in the Windows ones as well. If anyone can provide me with this information, that would be very helpful. Thanks!
Old 18-05-2009, 5:57 PM   #14
swabes
Posts: n/a
Great post Ginoworm I'm looking at one of these as a Win 7 RC1 Media Center machine as well.
What TV Tuner are you using?
What is the performance like when displaying the TV Guide over live TV - does the live TV stay smooth?
Old 18-05-2009, 6:54 PM   #15
jameson_uk's Avatar
15,258, Level: 29
Points: 15,258, Level: 29 Points: 15,258, Level: 29 Points: 15,258, Level: 29
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 87, Got 550
Nearly forked out £150 on the spot until I read this... Is a real shame as the Zotac ION boards have gigabit LAN but with the dual-core board costing more than the Linux model this is kind of not worth it.
Off to research how much bandwidth is needed to stream BD ISO files....
Old 18-05-2009, 7:42 PM   #16
jameson_uk's Avatar
15,258, Level: 29
Activity: 1.9%
OK think I have just about talked myself out this ...
£150 seems like a throw away price as a playback machine for the bedroom but it is only 1GB so you are looking at upgrading to 2GB to make it useable for a start. Then you only get an 8GB SDD. This does not look big enough to load Win7 which would leave you with XP (which I do have a copy of lying around)
If it had a 16GB SSD or gigabit LAN I think I would have bought one by now. Not sure I can justify the extra £100... or can I
Old 18-05-2009, 7:53 PM   #17
DLPMaybe's Avatar
4,846, Level: 16
Points: 4,846, Level: 16 Points: 4,846, Level: 16 Points: 4,846, Level: 16
Thanks: Gave 45, Got 58
Keep linux on it and use xbmc. That's what I'm going to do as soon as I get find somewhere that actually has the 150 quid one in stock.
Old 18-05-2009, 8:11 PM   #18
jameson_uk's Avatar
15,258, Level: 29
Activity: 1.9%
One of the main reasons for getting a bedroom playback box was to stream TV from MP on my main HTPC in the front room. All the DirectX stuff means MP won't run under Wine right? And XBMC won't stream TV from MP?
I did once try and get the streaming working with Ubuntu on my main PC but had no joy. Also WAF really needs me to have both front ends the same else I will get even more grief
Old 18-05-2009, 10:13 PM   #19
2,307, Level: 11
Points: 2,307, Level: 11 Points: 2,307, Level: 11 Points: 2,307, Level: 11
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 1, Got 1
Iv been looking at building a htpc but to be honest just cant be arsed . Is this a good alternative? would there be a way of recording tv onto it, streaming from the web and hooking up a external hard drive with all my music n films on
Old 19-05-2009, 12:22 PM   #20
sibeer's Avatar
6,864, Level: 19
Points: 6,864, Level: 19 Points: 6,864, Level: 19 Points: 6,864, Level: 19
Thanks: Gave 71, Got 115
My Dell Mini 9 has 1GB of RAM and a 8GB HDD, runs Windows 7 fine (after a little trimming in vlite). With the support of the chipset there is no reason the basic model wouldn't be a decent Windows Media Center.
Oh and the Gigabit LAN really isn't needed for a HD streaming device. Stop looking for reasons not to buy and get one
Old 19-05-2009, 1:16 PM   #21
DeanTheDon's Avatar
3,483, Level: 13
Points: 3,483, Level: 13 Points: 3,483, Level: 13 Points: 3,483, Level: 13
Thanks: Gave 116, Got 36
I'm hopefully getting one of the £150 models this week but i was just wondering what type of RAM these take cos I would like to upgrade to 2gb. Thanks.
Old 19-05-2009, 1:30 PM   #22
3,373, Level: 13
I read a review somewhere that said it had DDR2 800Mhz, though that was the £250 model and I don't know if it's going to be different - I would suspect not.
DeanTheDon (19-05-2009)
Old 19-05-2009, 1:59 PM   #23
4,246, Level: 15
Points: 4,246, Level: 15 Points: 4,246, Level: 15 Points: 4,246, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 0, Got 35
My question regarding the revo is how does it cope with iplayer.
One test would be for someone with 7MC to try tunerfreemce on it.
Old 19-05-2009, 2:00 PM   #24
DeanTheDon's Avatar
3,483, Level: 13
From THIS it appears to have 667MHz so would this be okay? Crucial 2GB DDR2 667MHz/PC2-5300 Memory Non-ECC Unbuffered*CL5 Lifetime Warranty - Ebuyer
Old 19-05-2009, 3:09 PM   #25
jameson_uk's Avatar
15,258, Level: 29
Activity: 1.9%
How much space is left on the disk (SSD tend to slow down lots when full)
Oh and the Gigabit LAN really isn't needed for a HD streaming device. Stop looking for reasons not to buy and get one [/QUOTE]
Old 19-05-2009, 3:38 PM   #26
jameson_uk's Avatar
15,258, Level: 29
Activity: 1.9%
had a quick scan of
Acer Aspire Revo SFF NVIDIA Ion PC - HotHardware
and would appear it is SODIMM RAM
Old 19-05-2009, 4:55 PM   #27
DeanTheDon's Avatar
3,483, Level: 13
Okay, cheers.
Old 19-05-2009, 8:05 PM   #28
1,779, Level: 9
Points: 1,779, Level: 9 Points: 1,779, Level: 9 Points: 1,779, Level: 9
Acer Outlet: I've just come across this site - New Aspire Revo Ultra Small ION Platform Desktop - Acer Outlet - with the best prices I've seen. Up until now I'd never heard of them. Has anyone ever dealt with them?
Old 19-05-2009, 8:23 PM   #29
jameson_uk's Avatar
15,258, Level: 29
Activity: 1.9%
No but £17.50 for UK delivery would push the prices beyond others with free delivery...
Also whilst looking today (spent far too long trying to find somewhere with the £150 version in stock) I also came across this which says that once the initial batch of 8GB SSD are gone the £150 model will ship with a 160GB HDD (still same price)
Old 20-05-2009, 11:42 AM   #30
NaTT's Avatar
1,076, Level: 7
yes I heard that about the 8Gb SDD intital batch.
Wonder if this'll effect the folk with "Order Taken" status on Play.com, which means that they took your pre-order not telling you that they had too many pre-orders already and their initial allocation was already taken by them, but they weren't going to tell anyone that (still haven't).
At least now you can guess that the status means 4-5 days as that's what it says on the item.
But will the delivery have a new spec for this model......?
Cancelled my order. Hate being messed around.
Thread Closed
