About 8 months ago i decided it would be better to have a central point for all media and the best approach appeared to be a HTPC, I wasn't bothered up about PVR or Live TV as we have Sky.
So i started out by getting a cheap 2nd had shuttle PC which sort of did the job but it was ultimately to old and small to upgrade properly. This was sold on for a profit.
Then i decided to try the 360 approach so bought a 2nd hard 360 to stream content from my main pc however as most of you will know streaming HD content properly is a bit hit and miss and annoying when it doesnt work. Still have this as i love the games.
So i am back to the HTPC method but this time i want to keep a tight budget but also play/stream full HD content. So after some reading here is the spec list of the components which will make this budget HTPC.
Hardware:
Gigabyte GA-MA78GM-S2H Motherboard
AMD Athlon X2 5050e 45W Energy Efficient Retail Processor
2gb OCZ PC26400 800mhz Ram
Samsung SpinPoint 80GB 3.5" SATA HDD
EV Shiny Piano Black/Silver Super Slim Micro ATX with 200w PSU
Software:
Operating System - Windows XP
Media Front End - XBMC with EventGhost for custom MCE remote mapping
In the short term this box will be used to stream HD content, TV shows and Music from my main PC (Hence the small HDD). However eventually a blue ray disc drive and a larger hard drive will mean this is will be the central storage point for media. Maybe once Windows 7 Media Centre has become established and FTA HD channels are more available i might look at using it as a PVR.
Although I haven't got the components yet i have been testing the XBMC software on my main PC and so far so good, it looks fantastic in my opinion and seems to index and grab all relevant information/backdrops for Movies and TV. Music was previously setup using iTunes so all the iTunes artwork is embedded in my MP3's and ID3 tagged correctly.
The MCE remote needed to be programmed to utilise all of the functions and i spent some time doing this and so far it seems to work correctly. I have used a program called eventghost with some plugins to auto start the application, disable to HID service (stops buttons being used by VMC) and map functions to keypresses.
The overall aim is to use the computer without a keyboard and mouse, its not perfect as i cant navigate the On Screen Keyboard for searching but it works ok. For maintenance and updates i will RDP into the box.
Here are some screenshots of the testing (note they are a bit of an odd size as i have been testing this in windowed mode due to my main PC not having a widescreen monitor).
Movies home menu hover, HD Movie backdrops fade in and out:
Movies selected, get a DVD cover view to navigate and on hover get information and relevant backdrop:
TV Shows home menu hover, HD TV Show backdrops fade in and out:
TV Shows selected, navigate by Show, then series and then episode. Get covers and thumbnails along the way, on hover get information and relevant backdrop:
Music home menu hover, HD Music backdrops fade in and out:
Music selected, get list to choose artist, album, song etc... from there get roller view which scrollers album art:
As you can see it looks great and has played all the media files i have thrown at it. I have also installed a few plugins installed which allow me access Last.fm radio, BBC iPlayer and i have been testing launching programs to access power DVD for blue ray (when i get it). I would also like to have some sort of sopcast stream so i can watch football but thats not a major problem at the moment.
I will update once i have got the bits and have built it with proper high res pictures
Hope you like
UPDATED BUILD PICS ON PAGE 2
UPDATED FRONT END PICS ON PAGE 3
