64bit MPEG-2 Decoder?
Old 21-11-2008, 9:48 PM   #1
2,677, Level: 12
Points: 2,677, Level: 12 Points: 2,677, Level: 12 Points: 2,677, Level: 12
Thanks: Gave 35, Got 1
I downloaded the Vista Codec Pack to get MP4 working on Vista.
I see it has options under 64bit Tools>Video decoder configuration>Codecs>MPEG2 for libavcodec and libmpeg2.
Will simply selecting one of these replace Vista's inbuilt decoder?
Also are there other MPEG-2 decoders for 64bit Vista Media Center?
Finally are any of them likely to be better - in the sense of quality, rather than performance - than Vista's default one as to be worth trying?
Thanks.
Old 21-11-2008, 10:14 PM   #2
6,019, Level: 18
Points: 6,019, Level: 18 Points: 6,019, Level: 18 Points: 6,019, Level: 18
Thanks: Gave 24, Got 56
Re: 64bit MPEG-2 Decoder?
Thanks.
Powerdvd's is the best IMO.
But others are Nvidia's purevideo
