Originally Posted by Bossk128 Does anybody have experience with getting LPCM from mkvs encoded with either DTS-MA or DD-TruHD through HDMI, specifically with MediaPortal but even with other software players?
I rip my Blu Rays with minimal changes, so even if I do transcode the video I tend to leave the audio untouched. My amp does not accept bitstream HD audio, but does accept LPCM. |
There are a probably a number of ways to achieve this, this is one method that I think should work:
Use LAV Audio as your main audio codec, but don't have DTS-HD or Dolby True HD ticked for bitstreaming.
Add ffdshow as a post-processing filter and have that set up like this:
Ensure that Uncompressed (raw) is set to 'all supported' (this is right at the bottom of the codec list).
You don't need to have any other ticks in the left hand column. Especially ensure that 'Mixer' isn't ticked as this can cause errors.
Output - Output formats for uncompressed or decoded streams - put ticks in '16-bit integer', '24-bit integer', 'AC3 (S/PDIF encode mode)' and 'Encode 5.1 streams only'
