Personally, I hate codec packs, I like to keep my install as minimalist as possible. If too many codecs are installed, I get confused as to which ones are working.
LAV filters are very popular, personally I prefer ffdshow, as it shows up in the right hand corner of the taskbar when working and tells you exactly what is going on.
I just install the minimum amount to get it working, so a splitter to split the files (I use gabest) plus ffdshow to bitstream DTS, DTS-HD MA and Dolby True HD.
I can't get ffdshow to do AAC audio codecs very well though, so I use LAV audio decoder, and tick just the aac codec for that.
