Originally Posted by djcla I deleted all the artwork thumbs etc and now i cant get anything to load lol.. Under music dynamic control should these settings be disabled or enabled? I have my music sorted like //server/share/atrist/album. Im getting the album covers straight away even after i deleted them all so not sure where they being picked up from. Anyway cant get backdrops to fetch and should i be seeing artist thumbs instead of folder name?
When you database view im not seeing that option?
Edit found somthing under switch view but only 2 artist showing hmm
Edit 2 ok i had folder.jpg in each album folder which must have been put there by wmp or something i have deleted all jpg files now |
Right ok, first off delete anything in the subfolders of
C:\ProgramData\Team MediaPortal\MediaPortal\thumbs\Music
(leave the folders there)
Then go into config and disable the dynamic content option to download coverart (fanart handler does this much better than the inbuilt MP function).
On the music database page in config do not tick the create artist or create missing thumb options but do tick the embedded option (and folder.jpg if you want to pick up images from there too)
Also tick the treat tracks in a folder as an album option (not sure what the defaults are on all this)
Make sure the place where your music is stored you ticked in the top bit of this screen and the only update new/changes since... option is unticked. Then re-import all your music. (then I suggest you re-tick the only update new/changed.. option so next time it will be much quicker)
Then fanart handler should download images as and when needed for artist thumbs and fanart (album artwork I trust is already embedded within your files?)
Now in MP you should be able to bring up the menu and choose the change view button which will bring up a list of things like album artist, artist, albums by age, genre etc..
Then the last thing (which thinking about it might have been the issue anyway...) is what thumbs are shown where is down to the skin. I would have thought that streamed MP would show artist thumbs most places.
eg.
this is a list of albums so no artist thumbs
this is a list of artists but the selected one gets a large thumb
this is a list of artist thumbs in coverflow layout
The same list in icon layout
They should also appear in music now playing
