jwindley,
I've tried Quick Time Alternative now but the installer says quite clearly that it does not include any DirectShow components. After it installs, there is no difference.
Daveybryce,
I installed your file MP4Splitter and it seems to be a step in the right direction.
DirectShow will now split all of my .mov files and some of them are even playable.
My situation at the moment:
I have the following codecs and splitters installed:
CoreAVC
Haali Media Splitter
Koepi's Xvid
MP4 Splitter
all the codecs that come with Vista 64 and extra ones bundled with Cyberlink PowerDVD.
Some of my movs are decoded completely and work well. Some of them decode just the audio, some of them think they are decoding the audio but output nothing.
I did find another Codec called 3ivx that seems to decode audio from the mov files fairly well. It might also decode some of the video as well. However, it is $10.00 to use after a trial period.
Has anyone else tried:
QuickTime DirectShow Source Filter: A QuickTime Playback Solution - MediaLooks
I am having trouble specifically with video files from this NASA page:
NASA - NASA High Definition Video
If anyone else has Graphedit, would they mind trying to play the file and letting me know what codecs and being use?
Thanks for the replies so far, they are much appreciated.
