| Problem playing VOB's
Hi folks,
OK, this issue seems to get done to death all over the place, but I can't find a solution that matches my problem!
I have a mediapc running windows 7 pro and cannot get it to play vob files in either media player or media centre, it displays the message "Windows Media Player encountered a problem while playing the file".
Up until recently I had been running vista on this pc and vob's were fine, but now I've upgraded/rebuilt I think I've missed something/messed something up.
During the rebuild, I installed ffdshow and haali for mkv's and they all work fine, thats it. I haven't installed any other players or codec packs, I like to keep it clean! The other thing I did was to run the MSDU app to replace the mfc codec with ffdshow to make sure it gets used in preference.
I will also have installed gspot and mediainfo.
Browsing to the vob folder shows icons as a single frame from the vob (think this is done by mediainfo).
Using graphedit, it maps the video stream as...
VOB -> MPEG-2 Demultiplexer Vid -> Microsoft DTV-DVD Video Decoder -> ffdshow Video Decoder -> Video Renderer
... and clicking the play button in graphedit plays the movie fine.
I have also rebuilt the other media pc's in the house which get used as 'extenders', all using windows 7 with just ffdshow. They play the vobs fine, the only difference here is that they haven't had the msdu app run on them, yet.
I want to use FFDShow for it's tweaking and integration with the MediaControl app, but how can I get it to play vobs as well?
ffdshow version : rev3078_20090917
Help!!!
Chris
