Originally Posted by jensrow I give it to you that the 4330 is faster than the 9400/Ion but the 9400 is also clearly better than the HD 3200 according to Notebook check: Ati Radeon HD 4330: 3D Mark 05 - 4969 Nvidia 9400M (Ion): 3D Mark 05 - 3394 Ati Radeon HD 3200: 3D Mark 05 - 2634
so taking a Zino HD with an equivalent dual core processor, blu ray and slightly weaker gfx it comes to £459, but does that include blu ray software, i.e. Arcsoft TMT or PowerDVD (not just cut down OEM stereo versions), if not that is another £70 on top? |
2 things to note about this...
Notebook review is looking at the 780M version which is the mobile version of the chipset, not the 780G which is the desktop version. Same architecture, but slightly defeatured to hit lower power numbers. The Zino HD is using the 780G which will offer slightly better performance over the 780M. Not much but it is slightly better.
However, the big thing here is that these scores are based upon 3D gaming. As stated earlier, yes the 9400 does have an edge on gaming, however, how important is 3D and gaming in an HTPC? To me, not very much.
What matters to me in a small box like this is video playback performance. It is an HTPC afterall, audio and video are really the key attributes. In that case, the 780 chipset is on par and in some cases, better than the 9400 which I provided in my links.
Frankly speaking, any UMA graphics solution today including the 9400 is really not an ideal solution for gaming. You can do it, but if gaming is at all important to you, a discrete solution would be much better. Hence the 4330 option addresses that need if it is important.
So, I stand by my statement that Ion graphics in an HTPC is about the same as the 780G chipset. No clear winner in that perspective.
As to the rest of the platform, they share similar specs though the Dell box seems more configurable with different options.
I have not seen any benchmarks that compare the Atom 330 to our Athlon 3250e or 6850e offered here. Probably have to wait for reviewers to get that data out there to see where things fall. Based upon internal data, I have reason to believe the Athlon will outperform the Atom but time will tell I suppose.
UPDATE:
Somone pointed out this similarly spec'd out All In One comparrison that pits a box with near identical specs to the Dell box vs. an AIO based upon Atom 330. Not exactly the best line up since the Atom 330 AIO is using a different chipset. However, testing does show off the CPU comparrison given the benchmarks they ran are less GPU dependent and more CPU dependent. It should provide some level of comparrison between the Athlon 3250e vs. an Atom in terms of CPU performance. . Though a head to head comparrisons beteen Atom/Ion and Athlon/780G would be nice. Between this data and the info I provided earlier on similar GPU performance, you can draw some conclusions
http://reviews.cnet.com/desktops/ave...?tag=mncol;txt
The price point of the Dell is very compelling. I think it is not only performance competitive with the Asrock solution, it also seems a tad more flexible in the config.
The advantage of the Asrock is that price includes a BD drive. However, if BD is not important, then you can config a pretty impressive solution using the Dell box as the base.
