AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Computers > Computer Systems > Home Cinema PCs
Notices
Problems playing Blu-ray and HD disks Westindieman Home Cinema PCs 8 06-01-2009 1:43 PM
Any good HD HDTV Recorder + Streaming box? studiox Streamers and Network Media Players 6 04-01-2009 8:07 PM
Overdrive - when best to use it? reddevil63 Rock Band Xbox 360 21 04-01-2009 7:30 PM
How to get sound from my Xbox > 42LG5010 > 5.1 System keydogg LG Owners' Forum 1 31-12-2008 6:15 PM
Annoying sound delay issue on SKY HD Recordings sometimes, and more! Waynester Sky HD 1 31-12-2008 6:05 PM
Old 31-12-2008, 6:21 PM   #1 (permalink)
Thanks: Gave 7, Got 3
Best DOLBY TRUE HD, DTS-HD,SACD,DVD-A sound card
My AVR doesn't support these audio formats, DOLBY TRUE HD, DTS-HD,SACD,DVD-A,
so instead of buying a new one I thought I might update to a media centre with a good soundcard that supports these formats.
I really want something with good audiophile hi-fi properties. I listen to a lot of stereo classical CDs so it must excel in this field.
I want to use the soundcard virtually as a preamp and only have audio frequencies going to five separate Hypex class-d power amplifiers. The soundcard would do all the digital decoding. IS THIS POSSIBLE?
Balanced outputs would be nice but not necessary.
I don't want to spend too much money, looking on this forum some of the soundcards cost over £500. Way beyond my budget.
Any suggestions please? Your suggestions will be greatly received.
SACD
Amplifier: Denon AVR-3805. Sagem PVR 6280T. DVD player: Pioneer DV-600AV. LCD TV 40 inch Samsung LE40m86BD. Epos ELS Subwoofer.
Speakers: KEF Q55 Main, Q9C Centre, Q8C Rear.
cirrus18 is offline   Reply With Quote
Old 31-12-2008, 6:33 PM   #2 (permalink)
Thanks: Gave 202, Got 62
Re: Best DOLBY TRUE HD, DTS-HD,SACD,DVD-A sound card
I use an ASUS X2 Sonar PCI soundcard. That has 7.1 analog outs into my amp for DolbyHD and DTS MA / HD over analog. The playback software is used to decode the format (PowerDVD) to the external outs.
Cost around £120 at the time (last year) but it sounds great and on par with my standalone Toshiba HD A1 HD DVD player via its analog outs.
I don't use the digital outs / ins, but they're there if you need 'em.
My Home Cinema http://www.avforums.com/forums/membe...nema-room.html
Donnacha is offline   Reply With Quote
Old 31-12-2008, 8:46 PM   #3 (permalink)
Wouldn't this be better? ASUSTeK Computer Inc.
Quote: Without Xonar HDAV1.3, Blu-Ray Disc goes down to DVD Quality on PC!
I didn't know that, did you?. I suppose that means everybody who has up to now been playing Blue Ray discs from their PC thinking they're getting HD quality are sadly mistaken.
Xonar HDAV1.3 Deluxe
Enjoy 100% Blu-Ray Quality Audio with HDMI 1.3 Compliance, Video Enhancement and 7.1 Channel Analog Output
- Full-HD Audio/Video digital output
- HDMI v1.3a compliance
- Non-downsampled 192kHz Blu-Ray audio
- Splendid Technology Video enhancement
- Complete Dolby True HD & DTS Master Audio support
Certificated HDMI 1.3 Support
Old 01-01-2009, 9:28 AM   #4 (permalink)
Thanks: Gave 8, Got 480
Does your amp support multichannel PCM over HDMI - if so then you may be best off with an ATI video card that supports this format (4550 or better?)
The Auzentech and Xonar HDMI cards are really only better than this solution if you need AVR decoding of bitstreamed True HD/DTS HD etc. - with the 4550 cards the PC decodes to PCM.
If you don't need an HDMI solution then you are in the realm of high quality decoding to analogue - and others will be better qualified than I to advise on these solutions.
BTW - I don't think there is a PC SACD drive is there - so I'm not sure SACD is possible? (It uses a bespoke optical format which requires a special drive to play non-hybrid discs)
Stephen Neal is offline   Reply With Quote
bosjames (13-05-2009)
Old 01-01-2009, 7:35 PM   #5 (permalink)
as far as I know its the software that downsamples the audio. Supposedly over analog, using PowerDVD for playback the best we are getting is 48khz/16 bit samples, which most Blurays are anyway! I don't think my equipment or ears may be good or trained enough to spot the difference between sample rates! I still think its something to do with software rather than hardware, although a HDMI connection bypasses the issue. Others are more educated on this than me, so that's about as far as my knowledge goes!!
Old 20-01-2009, 11:39 AM   #6 (permalink)
Thanks: Gave 3, Got 4
Did you try this solution Xonar? I'd be very interested if you did manage to get a soundcard/software solution to decode DTS Master Audio and Dolby True HD and pass it to the power amps via analog cables as I could find myself in a similar situation soon.
I note that it's actually quite an elegant solution, using the PC as the preamp and doing away with that stage at the Hi-Fi end. Of course, it's only elegant if you can get it to work, but it would help to cut down on boxes at least - and remote controls, for that matter.
glimmerung is offline   Reply With Quote
Old 20-01-2009, 12:55 PM   #7 (permalink)
Even on-board audio solutions will do this - the player software decodes the True HD or DTS HD tracks to PCM and then the on-board sound solution converts this PCM to analogue audio - just as with any other app. (Probably limited to 48K/16bit)
Onboard analogue sound solutions are notoriously poor quality - but there are higher quality analogue sound cards that do much better. This is a route many have taken - the card doesn't do the True HD/DTS HD decoding - the player software does.
Some graphics cards (ATI 4xxx series) and some IGP solutions (8200, 8300, 9200, 9300) DO support output of the decoded PCM via HDMI - again subsampled to 48K/16bit if originally at a higher sampling rate or bit-depth (not a huge number are)
The tricky bit is bitstreaming the True HD or DTS HD digital audio un-decoded via HDMI. This is not currently supported by IGP or Graphics card solutions (as it requires a Protected Audio Path - which AIUI Microsoft don't have standardised driver support for) and only the Xonar and Auzentech solutions (which use proprietary implementations requiring specific playback applications)
The Auzentech has not been released yet, the Xonar is shipping, but is very specific in OS terms - and doesn't support 24p video.
Donnacha (20-01-2009)
Old 20-01-2009, 9:06 PM   #8 (permalink)
Digicon's Avatar
Thanks: Gave 24, Got 240
If you want the Full HD audio experience through the PC at the moment the only solution is the HDAV 1.3 from Asus although expensive and still cannot pass 1080/24p it is the best solution for bitstreaming.
Now if you have one of the ATI 48XX series cards or one of the IGP's 8200/8300 or 9300/9400 and are willing to take a steep learning curve then Full HD audio is possible through those cards and M\B's i have mentioned.
The only way at the moment is to convert your Blu ray's to MKV format with .flac audio, All the necessary programs are freeware its just taking the time to learn how to convert them. And best of all MPC-HD or KmPlayer can play these MKV's back with no loss of picture quality or audio quality as .flac is the only as far as i know audio container that does not downsample through any windows operating system.
Forum Trader Feedback It works both ways see the POLL
Digicon is offline   Reply With Quote
Old 21-01-2009, 10:23 AM   #9 (permalink)
Thanks: Gave 93, Got 6
I'd be interested in this, any guides or directions on how to do it ?
eddiem74 is offline   Reply With Quote
Old 21-01-2009, 10:40 AM   #10 (permalink)
Thanks: Gave 13, Got 51
Yes but you will need to google them
andyUK101 is offline   Reply With Quote
Theydon Bois (21-01-2009)
Old 21-01-2009, 10:43 AM   #11 (permalink)
Rather than convert to MKV you could demux and wrap them back into a different container, such as m2ts. This is a lot quicker and simpler than converting to mkv, using FFDshow to decode things should result in non downsampled audio (at least i think)
Old 21-01-2009, 3:04 PM   #12 (permalink)
Theydon Bois's Avatar
Thanks: Gave 237, Got 408
"The only way at the moment is to convert your Blu ray's to MKV format with .flac audio, All the necessary programs are freeware its just taking the time to learn how to convert them."
Please note that any guides to articles that could be used as a form of piracy would be removed from here, and infractions could be given.
PC: Antec P180b; Corsair HX620W PSU; Asus P5K-E; Q6600 G0@3Ghz; 4Gb Corsair 1066Mhz RAM; 640Mb 8800GTS O/C; 22" Sammy 226BW
HTPC: Zalman HD160+, LG Blu Ray/HD Combi, E6600 CPU, 2Gb RAM, 1.75TB HDs, Media Portal
For help with your HTPC build, please read the HTPC FAQ
Opinions expressed here are my own and do not represent those of the AV Forums
Theydon Bois is offline   Reply With Quote
Old 21-01-2009, 4:46 PM   #13 (permalink)
Originally Posted by Stephen Neal View Post
Microsoft don't have standardised driver support for very specific in OS
If Microsoft is of no help and won't allow you to do what you want to do: what about Linux? Perhaps this is a better way to go.
Old 21-01-2009, 8:35 PM   #14 (permalink)
Linux is unlikely to have anything close to this. AIUI Protected Audio Path is a licensing requirement - AIUI no Linux Blu-ray player app is in the public domain yet (though this doesn't mean that Blu-ray player hardware doesn't use Linux) Similarly AIUI there isn't a Mac OS BD player app either yet.
Currently - on a PC - it is Windows or nothing.
(Ignoring illicit remastering of discs etc.)
Old 21-01-2009, 10:19 PM   #15 (permalink)
What about this then? Moderator Comment: Site link removed as it contains to a guide on disabling DRM on Blu-ray disc's
card, dolby, dtshd, dvda, sacd, sound, true
