Go Back   AVForums.com > Computers > Computer Systems > Home Cinema PCs
Today's price checkPowered by
Acer Aspire Revo R3600 Intel Atom 330 1.6GHz / 4GB / 320GB / Win Vista Home Premium
Acer Aspire Revo R3610 Intel Atom 330 1.6GHz / 4GB / 500GB / Win 7 Home Premium
Acer Veriton N260G Intel Atom N280 1.66GHz / 1GB / 160GB / WinXP Home
Dell Inspiron 546 (for home) AMD Sempron  2.2GHz / 2048MB / 250GB / DVDRW / Windows Vista Home Premium
Acer Aspire Revo R3600 Intel Atom 330...
Acer Aspire Revo R3610 Intel Atom 330...
Acer Veriton N260G Intel Atom N280 1....
Dell Inspiron 546 (for home) AMD Semp...
Acer Aspire Revo R3600L Ultra Intel A...
Dell Inspiron 545 MT (for home) Celer...
Acer Aspire M7720 Intel Core i7 920 2...
Acer Aspire Predator G7200 Defender A...
Acer Aspire M3800 Intel Core 2 Quad Q...
Apple iMac Intel Core 2 Duo 3.06GHz /...
 More...Prices updated November 21st at 6:30am and include delivery.
No Audio When Playing HD WWV Files JENeric PS3 1 05-03-2008 10:42 PM
No Audio Streaming .ts files to PS3 - Help!? stevemac2006 PS3 3 10-07-2007 5:32 PM
Where are WMA audio files stored? pigdog237 Xbox 2 04-07-2007 9:47 PM
Audio problem when joining 2 avi files suttonsboot Computer Systems 3 11-02-2006 10:57 PM
DivX Audio Files Astraeus Movies and The Cinema 2 28-11-2004 5:08 PM
Old 05-12-2008, 2:35 AM   #1 (permalink)
Thanks: Gave 139, Got 108
Got a Problem with Audio In Some MKV Files
Im getting this error message when i play certain 1080p mkv files:
Does anyone know why this is caused and how i can fix this?
(Using MediaPortal's own built in media player to play the files)
When playing those files the sound is choppy and not so good
50PZ80B. 42PX80B. PS3. Wii. Sony DSG820. KEF IQ5SE+Anthony Gallo+BK Gemini.Harmony 1000. SkyHD. HTPC:1080p/MediaPortal | Sony A700 / Sigma 10-20mm F4 / Sony 50mm F1.4 flickr
Maxamus is offline   Reply With Quote
Old 05-12-2008, 9:51 AM   #2 (permalink)
Theydon Bois's Avatar
Thanks: Gave 377, Got 583
Re: Got a Problem with Audio In Some MKV Files
Does it play ok in KMplayer? Not that that helps if you want to use MPs own player, but just to isolate the fact that it plays at all.
PC: Antec P180b; Coolermaster M620 PSU; Asus P5K-E; Q6600 G0@3Ghz; 4Gb Corsair 1066Mhz RAM; 640Mb 8800GTS O/C; 22" Sammy 226BW
HTPC: Zalman HD160+, LG Blu Ray/HD Combi, E6600 CPU, 2Gb RAM, 1.75TB HDs, Media Portal
For help with your HTPC build, please read the HTPC FAQ
Opinions expressed here are my own and do not represent those of the AV Forums
Theydon Bois is offline   Reply With Quote
Old 05-12-2008, 10:52 AM   #3 (permalink)
Thanks: Gave 80, Got 114
That looks like a subtitle stream not an audio one.
gvers is offline   Reply With Quote
Old 05-12-2008, 12:32 PM   #4 (permalink)
ye it looks liek a subtitle stream but its affecting the sound also for some reason. Sound is choppy in the files that show that error message. Its fine on the rest.
Is there anyway i can remove the subtitles from those files?
Old 05-12-2008, 1:52 PM   #5 (permalink)
You could demux and remux the mkv file. You will need to have a look in the MKV anyway to see what audio streams it has and see if they give you a clue to why the audio is choppy.
Old 05-12-2008, 2:05 PM   #6 (permalink)
I've managed to remove the subtitles by using a program called "MKVMerge 2.4". Very handy utility which lists the files contained in the MKV container (Video, Audio, Subtitles) and you just untick the files you want to remove from the file and save it
Regarding the choppy audio, well I've narrowed it down to it being a MediaPortal ONLY problem as the same files play without any audio problems in WMP Classic and WMP11. So, it must be a problem with MP's built in media Player (which i use).
Old 05-12-2008, 2:45 PM   #7 (permalink)
Thanks: Gave 0, Got 4
like i said in your other thread just install ffdshow see if that helps, or better yet coreavc (not free though) and see if that works any better for you, make sure you set media portal to use the ffdshow codecs from the config menu though.
baggett is offline   Reply With Quote
Old 05-12-2008, 2:52 PM   #8 (permalink)
im using those codecs already mate.
its only a problem with 1080p files. 720p files and divx play fine
Currently using AC3 also
Old 05-12-2008, 3:01 PM   #9 (permalink)
hmmm thats strange, 1080p files played fine when i was using ffdshow.
mabye try coreavc?
Old 05-12-2008, 3:45 PM   #10 (permalink)
Works in other plays fine.
Right i've stopped using MP's own built in player and have now told MP to use WMP Classic BUT i got a problem. When playing a movie now i am unable to use the remote anyway i can fix this?
Solve one problem and it creates anotehr one
Old 05-12-2008, 3:48 PM   #11 (permalink)
Thanks: Gave 19, Got 50
How did you rip these files? Does the original source play okay i.e. the Bluray disc?
TV Panasonic TX-37LZD85 LCD, Amp Cambridge Audio Azur 540R HPTC Silverstone LC17 case, Gigabyte 780G mobo, 2GB Ram, 4850e CPU, LG GGC-H20L Blu-Ray Reader & HD-DVD ROM, 'N' Wireless, Vista 32bit Ultimate. Xbox 360, Wii.
thepharcyde is offline   Reply With Quote
Old 05-12-2008, 3:52 PM   #12 (permalink)
The original plays Fine. Like i said, its just a problem with MediaPortal's own built-in Player - not other players. Infact MP's own built-in player has audio problems (stuttering, jerky etc) with 1080P files ONLY.
I've tried setting AC3 as the audio decoder of choice - Didnt help
Then i tried FFDshow - Didnt help
Old 05-12-2008, 4:25 PM   #13 (permalink)
lol as odd as this sounds ive just got a new 1080p rip, tried to play it through media portal and got the same message, however, movies i have previously ripped in 1080p work fine, so it seems the problem is only with certain mkv files.
to add more of a headache im using ffdshow to play the audiop through spdif, now if i open the rip using media player classic but still using ffdshow audio decoder it works fine, using ffdshow audio decoder through media portal does not work though, very strange.
i think ill spend the night investigating this, nout better to do lol.
Old 05-12-2008, 4:28 PM   #14 (permalink)
How did you rip the file then, software, settings etc.....?
Old 05-12-2008, 4:54 PM   #15 (permalink)
ok ive solved it (well some bright spark on the media portal forum did lol) i just found the thread.
basically its actualy a bug in media portal and vsfilter, you just have to download a patch and place it into your media portal root folder.
theres the link for rc3 media portal
http://forum.team-mediaportal.com/at...itles-core.rar
once the file has been placed into the root folder, go into the ffdshow filters menu from the start bar and click "vsfilter configuration", now in the general tab make sure it is set to "do not load".
now go into the halli media splitter settings from the start tab then options and hit the + next to the compatability option then make sure "autoload vsfilter" is set to on.
your mkv files should now work perfectly, the reason it only affects some files is its a subtitle issue so any file without a subtitle should not have been affected.
all of these settings were only tested with ffdshow mind, not sure about other players ect, and halli media splitter ect needs to be installed, but if your using ffdshow it should be already.
the origional thread is here if any one wants to read a bit more indepth about the problem:
Pop-up error message generated for certain MKV files with UTF-8 subtitles - Page 2 - MediaPortal Forum
hope thats of help to you, my movies work fine now.
Maxamus (05-12-2008)
audio, files, mkv, problem
