AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Computer Systems > Home Cinema PCs
LinkBack Thread Tools Display Modes
Old 30-09-2008, 12:59 PM   #1 (permalink)
Thanks: Gave 1, Got 0
New HTPC Jukebox - Help required
Hi guys, not sure if this is the correct part of the forum, so excuse me if its not.
Im currently midway through building a Touchscreen HTPC " Jukebox" and have a few questions for some of you who may be in the know. Ill start off however by listing the components i currently have.
ELO 15" Touchscreen
Pioneer Notebook Slotload CD RW \DVD
AMD 4400 + x2
4 Gb of DDR3 (had it from an aborted gaming rig build)
Asus Mobo
2 x 1 TB's of Storage drives
1 X 80 GB OS + Apps drive
Vista Ultimate
Crappy 300W PSU but its silent and small
Silent CPU fan
Asus 7.1 soundcard
Wifi card
These are going to be in a single floor standing unit in a jukebox style similar to http://www.jukebox45s.com/touchscree...x-software.htm
But is going to be finished in piano black and in composite (im leaving that up to my mate who designs and works with composite).
It will be a general HTPC for my stored ripped dvds and movies controlled by remote and/or touchscreen and also a jukebox controlled by the touchscreen.
The questions are
1- Which software solution would provide a good interface for both my movies and mp3s via both onscreen remote use and touchscreen. Ive looked a vmc and media portal but was wondering if there were any other viable solutions.
2-I want to have a glowing Wii type Led across the top when loading a disc into the slot load dvd. Any ideas on how to accomplish the necessary wiring or indeed if its possible at all?
3- I plan on changing the PSU but am unsure as to a good , cheapish and silent option. any ideas?
4- I will need to wire up a power switch to the front of the jukebox, but i am struggling with finding a good looking Momentary switch to wire up to the mobo power switch. Again any ideas?
5- And also looking for a discrete IR receiver solution, i would prefer one i can either butcher and incorporate it discretely into the design. i had a look at the official MS one but it look huge!.
Any other help or advice great appreciated.
dbthedon is offline
Old 01-10-2008, 8:02 AM   #2 (permalink)
Re: New HTPC Jukebox - Help required
44 views and no advice?
Anyone?
dbthedon is offline
htpc, jukebox, required
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Help required please, HTPC new set up. andip1967 Windows Media Center Edition MCE 1 04-03-2006 9:03 PM
Spec for New HTPC.....help required SB Pet Sounds Computer Systems 7 04-12-2005 11:01 AM
HTPC software required? garyc Computer Systems 4 12-10-2005 4:38 PM
Use your HTPC as an SDI enabled DVD Jukebox David PluggedIn Computer Systems 0 16-09-2004 10:43 AM
Help for HTPC as Cable pvr,jukebox, dvd player reddom Computer Systems 16 01-07-2003 10:15 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
