AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Computer Systems > Home Cinema PCs
LinkBack Thread Tools Display Modes
Old 29-09-2008, 11:29 PM   #1 (permalink)
Thanks: Gave 2, Got 1
Question Opinions Sought - Budget HTPC Build
Hi all
My trusty (no, reallly) Digifusion FVRT150 PVR PSU just died and I'm using that as an excuse to spend £300 on building an HTPC. Advice from the knowledgeable gratefully received:
Uses: Primarily watching Freeview (live/timeshift/recorded), watching dvd (on disc or rip), central home server for mp3s and backups of laptops. WAF is crucial :D
Bits:
Gigabyte GA-MA69GM-S2H AMD 690G Socket AM2 Onboard VGA 8 channel audio mATX Motherboard. £43@ebuyer. I need S-Video out to CRT telly for foreseeable future, hence this choice.
Corsair 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory Non-ECC Unbuffered CL5 Heat Spreader Lifetime Warranty. £27.50@ebuyer
AMD Athlon 64 X2 5000+ Socket AM2 2.6GHz Energy Efficient L2 1MB (2x512KB) Cache Retail Boxed Processor. £43@ebuyer. Seems the best combo of price/power/efficiency
Samsung HD502IJ SpinPoint F1 500GB Hard Drive SATAII 7200rpm 16MB Cache - OEM. £43@ebuyer.
Extra Value Sonata MATX MediaCenter Case - With 220W PSU 20+4pin. £40@ebuyer. Seems good value and very living room friendly: did toy with the Antec2480@£65 but gotta keep on budget.
Microsoft Windows Vista Home Premium - Licence and media - 1 PC - OEM - DVD - 64-bit - English. £71@ebuyer. I've not got time for any of this let alone on Linux, however good Mythbuntu is supposed to be.....
Pinnacle 3010IX PCTV Dual Hybrid Pro PVR / PCI Express / DVB-T/Analogue TV Tuner / Whitebox. £17.99@play.com. Bargain (or too good to be true?)The cost of this takes away some of the pain of actually using my own money to voluntarily buy Vista.
LG GH22LP20 22x Internal IDE DVDRW Lightscribe Drive Retail kit inc. Bezels. £17.99@play.com. Seems a good price for a retail kit with Nero and PowerDVD. Blu-Ray is just going to have to wait.
Trust Rc-2400 Vista Remote. £20 from Microdirect. Selected largely through boredom whilst trying to research: any bettter ideas?
Might add wireless KB, card reader at later stage.
Not decided on VistaMC / GBPVR / MediaPortal yet but leaning towards GBPVR based on my needs.
Total £320ish. Given that a Humax 320GB PVR is £180 at best this seems like it's worth doing.
1. What have I forgotten?
2. What are bad ideas?
Bob
arctorbob is offline
Old 30-09-2008, 7:01 AM   #2 (permalink)
Thanks: Gave 10, Got 26
Re: Opinions Sought - Budget HTPC Build
Thoughts...
AMD 4850e cpu:
http://www.ebuyer.com/product/144638
MS remote:
http://www.scan.co.uk/Product.aspx?WebProductId=143741
Change to 32 bit vista too. Could upgrade to the 750gb Spinpoint HDD if poss for the 32mb cache. Might be able to find a cheaper dvd drive on ebuyer. Wireless keyboard? How do you get s-video out from that motherboard?
devo is offline
arctorbob (30-09-2008)
Old 30-09-2008, 7:42 AM   #3 (permalink)
Thanks: Gave 4, Got 36
I have one of the Pinnacle cards - works fine in my system.
You'll be "okay" with a 500Gb, but because you mention DVDs, MP3s and backups AND for the price of the 1TB, I'd think about it. Although I appreciate you have a budget.
As above, I see no S-Video out on that board? Also echo the "e" series comment.
Remote looks "cheap" but it IS wireless, so...
Cafe Racer is offline
Old 30-09-2008, 9:40 AM   #4 (permalink)
Thumbs up Re: Opinions Sought - Budget HTPC Build
Thanks very much for the quick responses. In no particular order:
S-Video. From the ebuyer reviews:
"The card is supplied with a (standard PCI) height bracket which has a set of component & S-video sockets. The attached cable connects to a header on the MB. To answer an earlier question, this arrangement does not require a card! The sockets on the bracket are fed directly from the MB. The manual claims the Pb socket (one of 3 component output sockets) doubles up as the composite video out (but I haven't tried it). All in all, you get HDMI, S-video, component and composite video output as standard. I have only tried the S-video and it works."
4850e. This is exactly the sort of thing I posted for! I naively assumed that the one I chose was essentially the same (as it says energy efficient) but marginally faster for £3 more. I guess not.....................
32-bit. Happy to switch but curious why?
HDD. Point taken and with my ebuyer blinkers on I'd missed the 750GB compromise option (they only do 500GB or 1TB). I'll buy it from Scan together with the MS remote.
Remote. Agreed, it does look rubbish. I was tired.
DVD drive. It's still cheap and it definitely has the OEM software: most others seem sketchy on that........
Wireless KB. I was thinking Term Services or VNC for admin via laptop. Might add one later once SWMBO has forgotten about the initial £300
Thanks again
Bob
budget, build, htpc, opinions, sought
Refbacks are On
Thread Thread Starter Forum Replies Last Post
A budget HTPC build mid_gen Home Cinema PCs 15 16-09-2008 10:24 AM
not another htpc build!! £1000 budget..please look. Arcam_boy Home Cinema PCs 13 30-07-2008 7:48 PM
Opinions on the following HTPC build Ryboc Home Cinema PCs 2 27-04-2008 6:38 PM
Budget HTPC Build pumpman Home Cinema PCs 0 20-04-2008 1:05 PM
HTPC - budget build - Will this lot hack it?? dave_s13 Home Cinema PCs 5 19-07-2007 10:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
