| The UK's biggest and best home entertainment electronics forums | |||||||||||||
| 4 million visitors each month | |||||||||||||
| | Thread Tools | Display Modes |
| | #1 (permalink) |
| New Member | For Sale : DreamBox Dm7020si Satellite Reciever With 40GB Hdd
I have a DreamBox DM7020si Satellite Reciever for sale with a 40GB HDD so it will allow u to record 40 hrs of sat like a sky plus box It is a genuine box and not a clone like many out there Collection or post is ok Looking for £175 inc p&p Discription: This is truly the future of satellite viewing. The DM7020-S is a digital satellite receiver with full Ethernet communication capabilities. Power PC driven with Linux operating system for endless possibilities. This Dreambox 7020 Si digital satellite receiver with full Ethernet communication capabilities. Power PC driven with Linux operating system for endless possibilities, 250 MHz PowerPC Processor(350 Mips). Linux open source (most parts under the terms of GPL) Integrated Compact Flash Interface Slot 1 x DVB Common-Interface Slot 2 x Smartcard-Reader MPEG2 Hardware decoding (fully DVB compliant) Supports Linux Standard API (Direct-FB, Linux-FB, LIRC) Big-size LC-Display USB Port 10/100 MBit compatible Ethernet Interface Modem 12V switch cinch V.24/RS232 Interface Common NIM DVB-S 32 MByte Flash Channel-change time < 1 second 96 MByte RAM Unlimited channel lists for TV/Radio Integrated IDE UDMA66 Interface Supports directly bouquet-lists Support for internal HDD in any capacity Full automatic service scan Supports EPG (electronic program guide)' Supports multiple LNB-Switching control (supports DiSEqC) RF modulator S/PDIF Interface for digital bit stream out (AC-3) Supports own videotext Audio/Video cinch out Fully adaptable OSD in many languages and skin-support 2 x Scart-interfaces MINI-DIN connector for extern IR (send) DreamBox DM7020Si Parts DBS-Tuner: Frequency Range 950 . 2150 MHz Signal Level - 65 dBm . - 25 dBm Signal-to-Noise Level 12 dB max. DBS-Tuner Input Connector F-Type female Input Impedance 75 Ohm AFC +/- 3 MHz Demodulation Shaped QPSK FEC Viterbi and Reed-Solomon Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation Roll-off Factor 35 % Demultiplexing according ISO 13818-1 Common-Interface: Common-Interface Power Consumption max. 0,3A/5V Output analog: Output Level L/R 0,5 Vss on 600 Ohm THD > 60 dB (1 kHz) Crosstalk < -65 dB Video decoder: Video Compression MPEG-2 and MPEG-1 compatible Video Standard PAL G/ 25 Hz Video Formats 4:3 / 16:9 Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart) Letterbox precolating for 4:3 TV-Device Audio decoder: Audiokompression MPEG-1 ∓ MPEG-2 Layer I and II Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz Output digital: Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output optical (AC3) Video parameter: Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard> TV-Scart: Output: FBAS,RGB,S-Video over OSD selectable VCR-Scart: FBAS Mini DIN: I2C for stearing of external devices IR funktion Ethernet: 10/100 MBit compatible interface Function Update of Firmware, Connect to PC USB: USB 1.2 connector Serielle Interface RS 232: Typ RS232 bidirectional Bitrate 115,2 kBit/s max. Plug Connector SUB-D-9 Function: Update of Firmware Pins: 5V SDA (I2C-Kanal 2) SCL 3,3V GND IR-Output GND LNB power and polarisation : LNB Current 500mA max. ; short-circuit-proof LNB Voltage vertical < 14V without load, > 11,5V at 400mA LNB Voltage horizontal < 20V without load, > 17,3V at 400mA LNB shut-off at Standby-Mode UDMA66 IDE Interface: Intern for connect HDD Compact Flash - Reader Count of active satellite position: DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION DiSEqC - Rotor Control Physical specification: Ambient Temperature +15°C...+35°C Humidity < 80% Size (W x D x H): 374 mm x 230 mm x 75 mm Weight: 1,8 kg without HDD Power consumption: < 20W (in operation, horizontal polarization / 400mA LNB current) < 11W (in operation, without LNB) < 4W (Deep-Standby-Mode) Input voltage: 230V / 50 Hz alternating acurrent +/- 15% Location: Manchester I have read the trading rules and agree to abide by them at all times until the transaction is concluded to the satisfaction of all parties involved : Yes. -------------------------------------------------- This message is automatically inserted in all classifieds forum threads. By replying to this thread you agree to abide by the trading rules detailed here. Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment: 1) Landline telephone number. Make a call to check out the area code and number are correct too! 2) Name and address including postcode 3) Valid e-mail address (no disposable addresses such as @gmail or @yahoo for example). DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself. Also we advise that the vendor post images of the items for sale. This helps your sale by showing the condition of the goods prior to dispatch. |
| Bookmarks |
| Tags |
| 40gb, dm7020si, dreambox, hdd, reciever, sale, satellite |
| Thread Tools | |
| Display Modes | |
