Digital scaler with ultra high bandwidth
The CP-255 series is a professional universal scaler with ultra high bandwidth (205MHz). It accepts both
analogue and digital signals and provides a variety of scaled DVI or HDMI resolutions on its output.
Features:
· Both digital and analogue inputs are format converted and pixel re-scaled. It provides a large range of
formats and resolutions to match the native resolution of your display to ensure highest picture quality.
· Analogue RGB Compliant input:
Supports PC RGB input up to WUXGA @60Hz.
Supports HDTV RGB/YPbPr/YCbCr up to 1080p @60Hz.
· DVI/HDCP/HDMI compliant input:
Operates up to 165Mhz (Up to UXGA @60Hz)
· Supports digital PC RGB output up to WUXGA @60Hz.
· Supports digital HD output up to 1080p.
· Integrated 8-bit triple-ADC/PLL.
· Integrated DVI/HDCP/HDMI compliant receiver.
· Dual high quality scaling engines.
· Dual 3-D motion video adaptive de-interlacers with adaptive edge- oriented adaptive algorithm for smooth
low-angle edge.
· Automatic 3:2 pull-down & 2:2 pull-down detection and recovery.
· The Proprietary Advanced Colour Engine technology gives:
Brilliant and fresh colour.
Intensified contrast and details.
Vivid skin tone.
Sharp edge.
Accurate and independent colour control.
· 3D noise reduction.
· Operates through on-screen OSD menu control and remote control.
Specifications:
format resolution framerate format resolution framerate
VGA 640x480 60/72/75/85 Hz 1080p 1920x1080 50/60 Hz
SVGA 800x600 56/60/72/75/85 Hz 1080i 1920x1080 25/30 Hz
XGA 1024x768 60/70/75/85 Hz 720p 1280x720 50/60 Hz
SXGA 1280x1024 60/75/85 Hz 576p 720x576 50 Hz
UXGA 1600x1200 60 Hz 480p 720x480 60 Hz
WXGA 1280x800 60 Hz 576i 720x576 50 Hz
WSXGA 1680x1050 60Hz 480i 720x480 60 Hz
WUXGA 1920x1200 60 Hz
PC (RGBHV) & HDMI input Component input & HDMI input
Input resolutions
UXGA 1600x1200 60 Hz 576i 720x576 50 Hz
WXGA 1280x800 60 Hz 480p 720x480 60 Hz
PC (RGBHV) & HDMI output
Output resolutions
· Input format: Analogue RGBHV, YPbPr, YCbCr; Digital via HDMI in.
· Input levels:
· RGBHV: 0.7Vpp @ 75 Ohm, H/V: 3~5Vpp TTL
· Y: 1Vpp@75 Ohm, Pb/Cb,
Pr/Cr: 0.7Vpp@75 Ohm.
· Input connectors:
· HD-15 female VGA connector plus stereo audio with 3.5mm phone jack,
· Component via 3 RCA jacks plus stereo audio via 2 RCA jacks,
· HDMI connector plus stereo L/R jack (when HDMI input is used with a DVI source)
· Output connector: HDMI type A connector
· Output format: Digital RGBHV.
· Power: 5V, 2.6A center positive
· Dimensions: 180(W) x 124(D) x 25(H)mm
· Unit weight: 0.6 kg
Product reference: CP-255
Asking £150 Delivered by post. /price drop/
Paypal or Bank Transfer.
Thanks!
I have read the trading rules and agree to abide by them at all times until the transaction is concluded to the satisfaction of all parties involved : Yes.
This message is automatically inserted in all classifieds forum threads.
By replying to this thread you agree to abide by the trading rules detailed here.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Landline telephone number. Make a call to check out the area code and number are correct too!
2) Name and address including postcode
3) Valid e-mail address (no disposable addresses such as @gmail or @yahoo for example).
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
Also we advise that the vendor post images of the items for sale. This helps your sale by showing the condition of the goods prior to dispatch.
