Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
BEWARE when buying CHEAP HDMI cables off EBAY!!! Jonathan Fletch Camcorders and Video Editing 15 12-01-2009 5:14 PM
I'm 30 Today... Argghh! chrisw Digital Photography General Chat 18 12-01-2009 4:59 PM
Thomson box almost dead, whats common for engineers to fit now? emporer Sky HD 10 12-01-2009 1:55 PM
Old 12-01-2009, 2:00 PM   #1 (permalink)
Thanks: Gave 67, Got 77
HDMI 4 way switching box - £30.00
Not sure how much these normally go for, but the RRP says £120.00 for these powered QED One Series HDMI 4 way switching boxes, so looks like a deal to me at £30.
QED One Series HDMI 4 Way Switching Box - Switching Boxes - Audiovisual Online - High Quality Audio Video Cables and Accessories
Features:
* Fully HDCP compliant (High bandwidth Digital Content Protection)
* Includes IR remote for easy switching between devices
* Will support the new HDTV resolution standards
* No need to disconnect and reconnect multiple devices
Spiderkid is offline   Reply With Quote
Old 12-01-2009, 3:32 PM   #2 (permalink)
Marc's Avatar
Thanks: Gave 192, Got 385
Re: HDMI 4 way switching box - £30.00
just to make you aware - they are also selling this:
QED HDMI Switching Unit - 4 Way - New 1080p Spec Compliant - HDMI, Component and DVI switches - Audiovisual Online - High Quality Audio Video Cables and Accessories
which to me, suggests the £30 one doesn't support 1080p, so it may be worth doing some research before buying
My DVD/HD-DVD/Blu Ray Collection
AV KIT: (TV) Samsung LE52M86, (Receiver) Onkyo TX-SR806, (Speakers) Canton Movie 150qx + 2x Canton 101, (DVD) Denon 1920, (HD-DVD) Toshiba HD-EP35, (Blu Ray)Tevion 1100UK, (Consoles) XBOX 360 Premium, Wii
Marc is offline   Reply With Quote
Spiderkid (12-01-2009)
Old 12-01-2009, 8:39 PM   #3 (permalink)
Thanks: Gave 100, Got 32
anybody used these are they 1080p compliant
mr gothic is offline   Reply With Quote
Old 12-01-2009, 10:01 PM   #4 (permalink)
Thanks: Gave 102, Got 209
https://www.paceshop.com/shop/produc...hing-box-4-way
This website says they are not 1080p compliant.
It doesn't mean it wont pass 1080p though, probably means its not HDMI1.3 compliant or can pass enough data to be classed as CAT 2.
Very tempted to get this for my 720p TV downstairs and to allow me to use my oppo with my 1080p projector.
Broadsword is offline   Reply With Quote
Old 12-01-2009, 10:10 PM   #5 (permalink)
But there advert on amazon says it will do 1080p?
The confusion over these HDMI 1.3, CAT 2 compliant is ridiculous.
It hink this will do 1080p no problem but cant be labelled as 1.3 compliant or CAT 2 compliant cos it wont do 1440p or tru colour.
Old 12-01-2009, 10:28 PM   #6 (permalink)
Marc's Avatar
didn't 1.3 add support for HD Audio? Perhaps it can only pass 1080p video but not sound as well.. only one way to find out it seems, as there doesnt appear to be any information on the net about this thing...
Old 13-01-2009, 3:09 PM   #7 (permalink)
Baldybouncer's Avatar
Thanks: Gave 774, Got 204
Dont care and dont need 1080p so ordered one!
Not all flatscreens have to be LCD!
Link removed for the final time
Baldybouncer is offline   Reply With Quote
Old 13-01-2009, 7:42 PM   #8 (permalink)
looks like a member is selling one in the classifieds maybe they would no
Old 13-01-2009, 9:18 PM   #9 (permalink)
Its been this price since before christmas.
Old 14-01-2009, 6:05 PM   #10 (permalink)
Thanks: Gave 1, Got 1
it does support 1080....but I worked out using my quad core media pc to be the media server to the ps3, so have dismantled my htpc, hence no need for the hdmi switch now!!
only used it once!
jimmylin97 is offline   Reply With Quote
Old 16-01-2009, 5:46 PM   #11 (permalink)
Mylo's Avatar
Thanks: Gave 166, Got 399
very nicely made piece of kit, just about to test mine out now.
Should help tidy up the wiring a treat
Mylo is offline   Reply With Quote
Old 16-01-2009, 8:44 PM   #12 (permalink)
hi
please let me know if its ok with 1080p,im really tempted to buy this
cheers
Old 18-01-2009, 9:26 PM   #13 (permalink)
Mylo's Avatar
my pc is set at 1080p 24hz and once booted up runs bluray films perfectly through the QED box
I get an incompatibility warning during bootup but that is the pc changing resolutions for some reason I think.
The QED appears to work flawlessly.
mr gothic (18-01-2009)
Old 19-01-2009, 3:37 PM   #14 (permalink)
What about bitstreaming DTS MA HD sound? Can you do that using your set up?
Im assuming theres not a problem but someone raised it as a potential issue.
Old 20-01-2009, 1:32 PM   #15 (permalink)
Mylo's Avatar
can't check it I'm afraid mate, only got an old school amp
box, hdmi, switching, £3000
