Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 26-05-2003, 12:31 AM   #1 (permalink)
siluro's Avatar
Thanks: Gave 1, Got 2
Huskys KulerKube - Fosters Style
At the mo Asda/Wallmart have got these really cool (bad pun) fridges on offer for £90 inc 20x200ml bottles of fosters.
There a 1/3 of the height of the ones you see behind bars in pubs and clubs in blue with big fosters logo`s on the sides, and a the best bit is there silent (small fridge noise when ya stick your head right up to it)
lee
You say im a freak like its a bad thing?
siluro is offline   Reply With Quote
Old 27-05-2003, 12:18 AM   #2 (permalink)
Sounds similar to the Stella branded Husky fridge I got from Sainsbury's a while back. Cost £80 (no beer though )and I can verify it's quiet since I sleep in the same room. Holds 48 cans
cskates is offline   Reply With Quote
Old 27-05-2003, 1:09 AM   #3 (permalink)
siluro's Avatar
arr thought id seen somthing like em before, that must have been the ones then. Great little coolers tho arnt they.
Old 30-05-2003, 7:15 PM   #4 (permalink)
Thanks: Gave 0, Got 3
How big are these fridges - are they under counter size or smaller?
I bought a plain white Huskys glass fronted fridge of ebay a little while ago. The problem is it makes the noise it makes. It is silent most of the time, but the cooling fan spins up about twice an hour for a few minutes and makes a hell of a noise.
Are these ones from ASDA silent all the time?
Cheers,
Dave
Sanyo Z4, Prismasonic H1000 Anamorphic Lens, 105" Fixed 21:9 Screen, Mackie 626 LCR, Mackie 624 surrounds, Mackie HRS120 sub, M-Audio Delta 1010, HTPC, Sky HD, Mark Grant/Bettercables cables
crawf1982 is offline   Reply With Quote
fosters, huskys, kulerkube, style
