15-09-2007, 2:13 PM
#1 (permalink)
Thanks: Gave 459, Got 537
Panasonic SC-PT850EB-K Home Cinema £274.49
Panasonic SC-PT850EB-K Home Cinema £274.49 Dlivered
Use discount code TEHMECN to get it for £274.49
http://www.laskys.com/home_cinema_an...ferred_site=ba
Specifications
http://panasonic.co.uk/home-cinema-s...eb-k/index.htm
250GB - PS3 (60GB) | XBOX 360 Elite | PSP | PS2 | XBOX
Panasonic 42PZ85 | Panasonic TH-37PX70 | Panasonic SC-PT850EB-K Home Cinema | Sky +
PC - Antec 900 Case, Quad Core Q9550 @ 3.4GHz, Asus P5Q Deluxe, Nvidia GTX 280, 4GB Ram
PSN: usama0 | XBOX Live: Usama2K8
15-09-2007, 3:10 PM
#2 (permalink)
Thanks: Gave 67, Got 17
Re: Panasonic SC-PT850EB-K Home Cinema £274.49
is this any good?
i don't have an amp or speaker setup, so would this be a good solution to surround sound for the following devices
i have a panasonic th42PZ70 tv, which is full hd 1080p and had two hdmi connections
i have sky + connected with RGB (possibly swap for sky hd one day)
xbox 360 elite needs to be connected to hdmi
dreambox (satellite box) connected with RGB
would the SC-PT850EB-K be equipped to handle the above devices?
what would be the best way to set the above devices up to the SC-PT850EB-K or would i need to buy something with more connections?
thanks
15-09-2007, 5:21 PM
#3 (permalink)
Originally Posted by techmob
is this any good?
thanks
Yep i have it and it's awesome!
If you just have an xbox 360 Elite and not a PS3 as well it's fine you will need a optical lead to connect it to the home cinema and the HDMI to TV for Picture. Just like my PS3
I have SD sky normal one not + and it's fine so + will work.
Everything should work fine!
15-09-2007, 5:55 PM
#4 (permalink)
Hi, yeah i only have an elite
i take it you have your ps3 connected to your hdmi on the tv, and this to the other hdmi on the tv
how have you got your sky box connected to it foir sound? my tv doesnt have an optical out, so with the SC-PT850EB-K only having one, my xbox would be connected to that but what about other devices
thanks
15-09-2007, 6:24 PM
#5 (permalink)
thanks
OK i will check how iv'e done it!
17-09-2007, 4:33 PM
#6 (permalink)
thanks
Sorry for my late reply!
I have conected it with phono leads - audio out sky to audio in home cinema.
20-09-2007, 12:27 PM
#7 (permalink)
Thanks: Gave 13, Got 0
Hi thanks for this but I can't find anywhere to enter that code.
Can you please tell me where the opportunity is to enter it in the buying process?
20-09-2007, 5:06 PM
#8 (permalink)
It's out of stock now so i can't find out for you ill find out for you tho!
20-09-2007, 5:19 PM
#9 (permalink)
So when they get it back in stock add it to your basket then go to the checkout then Log in or if you don't have an account Make a new one then once you have loged in there will be a box for the discount codes!
20-09-2007, 6:17 PM
#10 (permalink)
Now even cheeper £269.99
Enter discount code TEHMECN
20-09-2007, 7:14 PM
#11 (permalink)
Out of stock will let you guys when it's back in stock!
21-09-2007, 9:48 AM
#12 (permalink)
Not sure if I'm being thick here but how do you know if it's out of stock? I can't find where it says if it in stock or out of stock anywhere.
Do you know that it's in stock when you can see a voucher code box?
Sorted it now, Just ordered it £269.99 - Bargin price, just hope it arrives in good time. Thanks usama.
21-09-2007, 3:00 PM
#13 (permalink)
Yep it does not tell you out of stock or in stock but when i said it's out of stock it was because it did not let you click add to basket it said Notify Me When Available!
21-09-2007, 3:03 PM
#14 (permalink)
I odered mine and it said it was comming on Saurday but on Monday they sent me an email saying that it will come on Thursday!
And that the date on the first email was just and estemate!
17-10-2007, 8:34 AM
#15 (permalink)
Thanks: Gave 813, Got 248
anyone have this yet, any better than sammys THX35...?
Also, anyone know how long the discount code will last?
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
