Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 29-11-2002, 10:36 AM   #1 (permalink)
Mark Ward's Avatar
Thanks: Gave 87, Got 11
WTD: Cheapest (Supermarket?) Multi-Region DVD Players offer
Looking for the best bargain supermarket DVD player that can be multiregion hacked.
Hey I'm a tightwad and this is to give as a Christmas present!
Mark.
I ♥ Linux
I use Linux for:- CCTV (Zoneminder), Telephones (Asterisk), Raid Storage (UnRaid) & HTPC (LinuxMCE - When I finally get it working).
Next project:- Linux Home Automation (probably using MisterHouse)
Mark Ward is offline   Reply With Quote
Old 29-11-2002, 4:18 PM   #2 (permalink)
General Skanky's Avatar
Thanks: Gave 23, Got 26
The Mico Celo is multi out of the box for £100 at Sainsburys. Has all the connections you need and does the job. Budget build feel to it though, but if you're not fussy..............
Guy
Onkyo TX-SR875 B&W MT-30 Panasonic 50PH9 PS3 Sky HD
General Skanky is offline   Reply With Quote
Old 29-11-2002, 4:33 PM   #3 (permalink)
adox's Avatar
rs in dublin do a cyberhome multi region for 110 euro(about £70 st) tou can order online@ www.richersounds.ie
adox is offline   Reply With Quote
Old 29-11-2002, 9:55 PM   #4 (permalink)
Super Moderator
Thanks: Gave 289, Got 161
Big 'W' do a player and 10 (ten ) dvd's for £99. Not sure if it carries THX certification though.
Opinions given are my own and are not associated with avforums.
lynx is offline   Reply With Quote
Old 29-11-2002, 10:35 PM   #5 (permalink)
gringottsdirect's Avatar
Thanks: Gave 1, Got 11
Apparently not.
See here www.thx.com/consumer_products/av_equip.aspx
Je voudrais manger boire et baiser.
gringottsdirect is offline   Reply With Quote
Old 05-12-2002, 4:34 PM   #6 (permalink)
Thanks: Gave 0, Got 6
Safeways
My local Safeway's leaflet has the Apex DVD player @ £59.99 Model appears to be AD2100 but apart from that I know nothing.
eeek is offline   Reply With Quote
Old 05-12-2002, 5:17 PM   #7 (permalink)
Mark Ward's Avatar
Hi Benji
Yep, That's the best deal I found. Previous Apex players have had handset hacks for Multi-Region and Macrovision disable. Guess I'll search the net quickly on this one then pop down the supermarket.
Cheers,
Mark.
I ♥ Linux
Old 06-12-2002, 12:26 PM   #8 (permalink)
this any good
http://cgi.ebay.co.uk/ws/eBayISAPI.d...943381606&rd=1
i have one superb
tonynw is offline   Reply With Quote
Old 06-12-2002, 5:23 PM   #9 (permalink)
beavis
Posts: n/a
Not a supermarket, but Dabs.com have a DVD player at £58 online, not got them in stock for a couple of days though yet. The brand is Dabsvalue so not so sure about the quality, but I'm looking for Christmas presents, so after a cheap one for mum + Dad!
B.
Old 06-12-2002, 8:51 PM   #10 (permalink)
machine at dabs is the same that was being sold by superdrug about 3 weeks ago can make multi region but wont play vcd or mp3 and are prone to power supply problems they where £64.99
Old 07-12-2002, 7:41 AM   #11 (permalink)
Posh Bloke's Avatar
Thanks: Gave 29, Got 0
Just picked up a Bush DVD2024 from Tesco for £85
Multi region straight from the box including RCE ones!
Selectable raw NTSC output or PAL conversion.
Not bad looking considering the price.
Very quiet mechanism.
Good on screen menu's.
Can't fault it for the price
Posh Bloke is offline   Reply With Quote
Old 11-12-2002, 5:19 PM   #12 (permalink)
Steve Bate's Avatar
Thanks: Gave 23, Got 9
Mark,
Just picked up an Alba 108 from Argos £69 for my folks. I asked on the DVD forum for a "Cheap as chips" player and allegedly it's quite good!!
Steve
Steve Bate is offline   Reply With Quote
Old 12-12-2002, 7:49 AM   #13 (permalink)
damtom1
Posts: n/a
I've bought a multi region player for my son from Richer Sounds.They have two models available,by Acoustic Solutions,both £69.95.
Old 13-12-2002, 11:39 PM   #14 (permalink)
DVDcake's Avatar
Thanks: Gave 1, Got 3
Lidl stores are currently doing a weekly special on a Supervision 2550 dvd player which is advailable in silver and black and according to the box plays Mp3 and supports DTS as well as having Dolby digital decoding and seperated line outputs and component video connections, all for £69.00
Don't know if it's multi-region though although most cheap players are.
'Who looks at a screwdriver and thinks, o-hoo this could be a little more sonic?!'
'What, you never been bored? Never had a long night? Never had a lot of cabinets to put up?
DVDcake is offline   Reply With Quote
Old 15-12-2002, 7:16 PM   #15 (permalink)
Dansai 1010 from Tesco Extra, if they have them in stock £69.99
plays the lot inc SVCD + DVD-R, multiregion and macrovision disable
bargain
MackemX is offline   Reply With Quote
cheapest, dvd, multiregion, offer, players, supermarket, wtd
