3.5 million visitors each month
Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Old 27-06-2007, 8:24 PM   #1 (permalink)
Thanks: Gave 49, Got 107
Maplin speaker cable on offer - but any good ?
I suspect not - but spotted it on another forum so thought I'd re-post here
Original 9.99/metre price seems a bit suspect - and 1.5mm seems thin
Air Bass Flex 1.5mm² Bi-Wire Speaker Cable N92CK
Manufacturer: Profigold
4 Core High Performance cable -ideal for Bi Wiring Speakers to transport the mid/high and low frequencies in separate pairs
Solid Core conductor produces outstanding Bass response
Silver Plated OFC Conductors deliver increased sense of clarity & tightest bass
Additional Air Foam Insulation layer ensures transient response of high frequencies
This product is sold in units of 1 meter cable up to a maximum length of 50m.
Orders placed for the quantity of 50 metres, or multiples of 50 metres will be supplied on a reel : otherwise the cable will be supplied cut to length.
To place an order for this product, order the Maplin Order Code (N92CK) times the total number of metres required.
Down from £9.99 to 99p a metre
Pioneer 2011, Tannoy R3s, Tannoy RC, Tannoy M2s, SVS PC-Ultra13
Buckster is offline   Reply With Quote
rozzar (27-06-2007), Tyler Durden (03-07-2007)
Old 27-06-2007, 10:41 PM   #2 (permalink)
rozzar's Avatar
Thanks: Gave 19, Got 14
Re: Maplin speaker cable on offer - but any good ?
cheers for that Mark....have ordered a 50m reel for £49.47 inc free shipping. It'll do for the new car stereo install i have planned hopefully :D
some more details
http://www.4rfv.co.uk/industrynews.asp?id=43
tbh if its silver plated it can't be that shoddy.
Panasonic Th42PX60; Pioneer VSX-LX70/ Arcam FMJ P7
Wharfedale Opus 2/Opus Tri-centre/Polk RT-FX rears/2x Rel Stadium.
Samsung BD-P1400, Toshiba HD-XE1
rozzar is offline   Reply With Quote
Old 30-06-2007, 12:18 PM   #3 (permalink)
Thanks: Gave 52, Got 12
Looks like its all gone
Fat Tony is offline   Reply With Quote
Old 30-06-2007, 11:35 PM   #4 (permalink)
rozzar's Avatar
nice cable btw...it arrived the other day :D
Old 02-07-2007, 10:49 AM   #5 (permalink)
Thanks: Gave 2, Got 1
I picked mine up at the local store on Sunday no problem - do not believe the maplin web site. Very nice cable, sounds very fine indeed for 99p per meter!
Cheers,
geoff
geoffgjones is offline   Reply With Quote
Fat Tony (02-07-2007)
Old 02-07-2007, 4:39 PM   #6 (permalink)
rozzar's Avatar
quite flexible too...will be just the thing for the car!
Old 02-07-2007, 4:55 PM   #7 (permalink)
Cheers,
geoff
Now, why didn't I think of that - there's one on the high street so will see if the missus will see if any is in stock (I can't get down there on school night!).
Old 02-07-2007, 11:09 PM   #8 (permalink)
Thanks: Gave 41, Got 68
Use this link to check stock for this cable in your locality
http://www.maplin.co.uk/NearestStore...;208jz&doy=3m7
(plenty available in mine)
peskywinnets is offline   Reply With Quote
Old 03-07-2007, 12:00 PM   #9 (permalink)
Thanks: Gave 100, Got 41
There is still stock of this stuff at most stores, at 99p reduced from £9.99 per metre it's a steal.
I think I'll buy up the stocks at my local on my way home.
I may have some left over if anyone can't find any.
Only other price I can find for this is £7.20 a metre from ClearlyAV
*Edit* There is an ebay seller that has this for £2.50 Per M *Edit*
Tyler Durden is online now   Reply With Quote
Old 03-07-2007, 12:22 PM   #10 (permalink)
I found someone selling it for £400 for a 50m drum
http://www.hdmi.co.uk/profigold_screwable_plugs.php
Old 04-07-2007, 12:20 PM   #11 (permalink)
Thanks, all. Just picked up the last 32m at Bishopsgate store! I must say this does look and feel like very nice cable.
My only hope is that I've got enough (I did not measure up) - the last thing I need now is to run short and have the last few feet, or one speaker, connected by some cheap bell-wire!
Actually, if I do run short, I'll probably split the x4 cable into two and use that for the rear speakers. That should be ok, right?
Old 04-07-2007, 1:45 PM   #12 (permalink)
Yes that is fine - but one of the pairs of cores are unmarked. When bi-wiring this does not matter, as you can tell which is which. However, if you split them, make sure you have a meter to check that you are wiring the speakers 'in phase' or you will get bass suck-out. If your speakers are grounded independantly of the amp (as they sometimes are in a car system), you will blow the amp up!
Enjoy!
Geoff
Old 04-07-2007, 2:54 PM   #13 (permalink)
Geoff - thanks for the tips.
Maybe I should split the x4 cable into two x2's , lay it out flat and then place a few blobs of tippex at each end of one core. And then double-check!
Old 05-07-2007, 7:32 AM   #14 (permalink)
hi guys sounds a good deal..can you help me out here tho please?
am a complete newby and just ordered an Onyko 674 and new Kef 3005, but i need speaker cable...will this cable from maplin do the trick? my local has it in stock at the 99p /m
also, and forgive me here as i have not yet recieved the speakers, do i need plugs/terminated??? to connect in to the speakers/amp? if so what and where? any help and advice on this would excellent.
mark09 is offline   Reply With Quote
Old 05-07-2007, 7:56 AM   #15 (permalink)
Mark09
Yes, I'm sure this speaker cable would be fine for this set-up and I would snap it up before it disappears.
You don't need plugs and can always add them later on.
cable, good, maplin, offer, speaker
