01-02-2007, 7:08 AM
#1 (permalink)
| | Prominent Member
Thanks: Gave 919, Got 472 | Varilight remote/touch dimmers
Single chrome for £13.75 from an ebay wholesale guy. I got one of these and can confirm brand new. Decent guy too. Got loads of other varilight stuff too. http://stores.ebay.co.uk/ElectricalW...Q3amesstQQtZkm
Mods: This isn`t me, and i know about linking to ebay, but i figured it is a good bargin to share |
01-02-2007, 8:32 AM
#2 (permalink)
| | Prominent Member
Thanks: Gave 823, Got 333 | Re: Varilight remote/touch dimmers
but these are cheaper with tlc direct. look here Quote:
Originally Posted by Paulie-W Single chrome for £13.75 from an ebay wholesale guy. I got one of these and can confirm brand new. Decent guy too. Got loads of other varilight stuff too. http://stores.ebay.co.uk/ElectricalW...Q3amesstQQtZkm
SVS PB13U | SVS SB12+ |I live in Peckham and still alive | Canon 450D . 24-105L . 70-200L |
01-02-2007, 11:50 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 198, Got 137 | Re: Varilight remote/touch dimmers
I can agree with OP, I have alos used xbensunderland@aol.com and bought:
2 Gang 2 way 400w Chrome IQ Master Remote -Touch
A joy to deal with and delivered to Ireland within 2 days.
01-02-2007, 2:08 PM
#4 (permalink)
| | Veteran Member
Thanks: Gave 1,995, Got 446 | Re: Varilight remote/touch dimmers
Just let me get this straight....
This is a dimmer switch for a light that is controlled by remote control?
Is it possible to operate it using my Harmony 855?
__________________ Optoma HD70 with 95" Screen|Sky HD|Onkyo TX-SR606|Jamo A102s|120 gig XBOX 360|USA 500 gig PS3|Wii|Harmony One |
01-02-2007, 2:37 PM
#5 (permalink)
| | Member
Thanks: Gave 110, Got 13 | Re: Varilight remote/touch dimmers Quote:
Is it possible to operate it using my Harmony 855? | This is a dimmer switch for a light that is controlled by remote control?
Yes, its touch sensitive too!
ive got a harmony 895, but cant seem to get it to work!
would love to know how?
01-02-2007, 3:12 PM
#6 (permalink)
| | Veteran Member
Thanks: Gave 1,995, Got 446 | Re: Varilight remote/touch dimmers Quote:
Originally Posted by luke_1983uk This is a dimmer switch for a light that is controlled by remote control?
would love to know how? | It says in the EBay advert: Quote: |
Learns from any button on an existing remote controller
01-02-2007, 3:37 PM
#7 (permalink)
| | Member
Originally Posted by Azzin It says in the EBay advert:  | yeah you can control it with any normal remote with a button on the remote that you dont use, but i cant get it to work with the harmony, if you do what the manual says it just overrides the original function of the remote, making it useless to the harmony, it is really anoying really need help with this?
01-02-2007, 4:18 PM
#8 (permalink)
| | Moderator
Join Date: Dec 2002 Location: Our house , in the middle of our street
Thanks: Gave 111, Got 442 | Re: Varilight remote/touch dimmers
The varilight dimmers are listed in the harmony database , just need to set them up a a device and away you go . Atleast on my 525 anyway
John
__________________ My opinions expressed here do not represent those of the AV Forums or it's associated websites Need a TV Guide ? Look here. |
01-02-2007, 4:49 PM
#9 (permalink)
| | Member
Originally Posted by johnscarlet The varilight dimmers are listed in the harmony database , just need to set them up a a device and away you go . Atleast on my 525 anyway
John | have you tried setting them up, even with varilight listed in the database, they are still a nightmare to setup, they are a complete nightmare, which i just cant get them set up right, everything else works fine apart from them.
thanks for trying to help though!
02-02-2007, 12:19 PM
#10 (permalink)
| | Prominent Member
I do have this on my harmony 655, setup from harmony website. works fine and have more range than the remotes advertised along with these dimmers.
02-02-2007, 12:29 PM
#11 (permalink)
| | Assured Advertiser
Join Date: Dec 2001 Location: Where ever you want me to be.
Thanks: Gave 95, Got 1,332 | Re: Varilight remote/touch dimmers
ideally you need varilight remote if there is a power cut they loose the learnt IR but no problem if you use the OEM codes from the remote
02-02-2007, 4:07 PM
#12 (permalink)
| | Member
Originally Posted by hornydragon ideally you need varilight remote if there is a power cut they loose the learnt IR but no problem if you use the OEM codes from the remote | OEM codes from the remote?
what are the codes? please
02-02-2007, 4:16 PM
#13 (permalink)
| | Assured Advertiser
the OEM codes are the default ones as used in the VARILIGHT optional IR remote control £5 ish
