Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 18-08-2004, 7:58 AM   #1 (permalink)
eviljohn2's Avatar
Thanks: Gave 76, Got 211
Philex Home Cinema Scart
Found this 1.5m scart to scart yesterday in Robert Dyas (the ironmongers) of all places for only £6.99 (RRP £14.99 although they claimed £19.99).
5* rated in What HiFi and seems to be just as good as my Philex Thor scart which retails for substantially more being the next range up. It's also got flatter plugs so I can actually get it in the back of my TV! Excellent cheap upgrade
eviljohn2 is offline   Reply With Quote
Old 18-08-2004, 8:15 AM   #2 (permalink)
Mylo's Avatar
Thanks: Gave 166, Got 399
Sounds like a bargain, they are £9.99 on their website.
Mylo is offline   Reply With Quote
Old 18-08-2004, 8:21 AM   #3 (permalink)
eviljohn2's Avatar
That's the one, pic here:
http://www.robertdyas.co.uk/acatalog/129609.jpg
I got mine from the branch at Leadenhall Market but they had loads of them.
Old 19-08-2004, 4:01 PM   #4 (permalink)
DaveP
Posts: n/a
Thanks eveiljohn2, grabbed the last two packs in the Oxford branch and a nice gents brolly for £3.50!
Dave
Old 19-08-2004, 9:18 PM   #5 (permalink)
Ekko Star's Avatar
Thanks: Gave 9, Got 138
Are these properly shielded scarts ? I need to get quite a few for day to day use and these look great for the price as long as they are foil shielded.
Ekko Star is offline   Reply With Quote
Old 20-08-2004, 7:20 AM   #6 (permalink)
DaveP
Posts: n/a
Hello!
According to the packaging they have "Multiple Shielding" (Copper and Aluminum). The cable is approx. 1cm in diameter.
Short of cutting it in half, I afraid I cant really tell you any more. There is Careline number you can ring if you wish: 08457 573479, the part number is 26481H.
Dave
Old 20-08-2004, 10:04 AM   #7 (permalink)
Ekko Star's Avatar
Cheers Dave
Picked a few up today. Nicely constructed and bargain for £6.99, though they are NOT fully screened. Not sure how they could have got 5*'s in a review if they're not ? Oh well.
cinema, home, philex, scart
