Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 03-01-2004, 11:45 AM   #1 (permalink)
Thanks: Gave 0, Got 4
Logitech Z-560, 400w surround sound speakers
If any one is looking for surround speakers for their computer, I have bought 2 sets of these from PC World at £59.99 each.(One for my son's Xmas present, and I was so impressed with the quality I have bought a set for my computer)
They are fantastic quality, with THX certified 50w speakers with removable covers and a huge 200w base speaker, but no central front speaker. These were reviewed as outstanding when they were £199, even now the same base speaker and 2 front identical speakers as a 2:1 system cost £149 at PC world.
Presumably discounted as not 5:1, but fantastic value nevertheless. Cheapest on line price I have seen is £160, they are to be found if you are lucky near the speaker section but probably with no price near them so they are not selling as they look expensive!
ken fowler
kenfowler3966 is offline   Reply With Quote
Old 05-01-2004, 4:01 AM   #2 (permalink)
DVDcake's Avatar
Thanks: Gave 1, Got 3
Just went and got these myself yesterday following this post, thanks Ken.
I only needed them for stereo and saw the other Logitech stereo system also. Thinking they might be cheaper still and forgetting what you had already posted I asked the till guy for the price.
'£149.99 sir',
'£150 !!!', I replied, 'but you have the same system with four speakers for £59.99'
'Ah but these are higher quality',he said in reference to the stereo system.
When I pointed out that the 4.1 system used the same speakers and was also made by Logitech he went very quiet.
So I intend to use the 4.1 system for stereo by not connecting the rear speakers and only feeding an input signal in via the front stereo channel. I can then use the fader control to maximise the power to the front channel. Hopefully there is no protection circuit that prevents the amp from working when used in this way.
'Who looks at a screwdriver and thinks, o-hoo this could be a little more sonic?!'
'What, you never been bored? Never had a long night? Never had a lot of cabinets to put up?
DVDcake is offline   Reply With Quote
Old 05-01-2004, 8:42 AM   #3 (permalink)
Thanks: Gave 49, Got 107
Thanks - I went to buy a pair yesterday - none on the shelves but there was one in stock at the back.
Very nice speakers indeed for 59 quid - very impressed - I decided to upgrade to these from a 5.1 setup of Creative Labs 5300 speakers and glad I did - I can sacrifice the centre channel for the increase in quality.
Cheers, Mark.
Buckster is online now   Reply With Quote
Old 05-01-2004, 9:05 AM   #4 (permalink)
Mark Ward's Avatar
Thanks: Gave 87, Got 11
I went and bought 3 sets on Sunday.
Haven't heard them yet but I've got a set for home, a set for work and another set for a pal at work who asked me to get him some.
Seem VERY good quality!
Thanks!
Mark.
I ♥ Linux
I use Linux for:- CCTV (Zoneminder), Telephones (Asterisk), Raid Storage (UnRaid) & HTPC (LinuxMCE - When I finally get it working).
Next project:- Linux Home Automation (probably using MisterHouse)
Mark Ward is offline   Reply With Quote
Old 05-01-2004, 3:02 PM   #5 (permalink)
monkeynuts's Avatar
Thanks: Gave 16, Got 19
WOW! just picked up a set from pcworld in Bath and for 60quid, they are incredible! the sub is worth the money alone, or buy a couple of sets and make a 6.1 satellite arrangment with another amp....
If anyone is interested, there were 4 sets left in stock, tho i might well be back down there to get another set. although the sales assistant was probably gonna take a set
Thanks for the spot Ken
monkeynuts is offline   Reply With Quote
Old 05-01-2004, 5:56 PM   #6 (permalink)
Doublespresso's Avatar
Picked up the last one from Staples Corner! It was in the storeroom not on dispaly on the shlef...
They look good <heavy too>
Cheers Ken! )
Doublespresso
Doublespresso
Doublespresso is offline   Reply With Quote
Old 06-01-2004, 5:28 PM   #7 (permalink)
Thanks: Gave 10, Got 50
Picked up a pair in Leicester today amazing for the money. They are a 4.0 design rather than 4.1 but suit my sounblaster platinum 4.0 card perfectly and play to earsplitting levels.
Bassbin is online now   Reply With Quote
Old 06-01-2004, 5:52 PM   #8 (permalink)
monkeynuts's Avatar
anyone know how i could make the sub take a standard phono input? i'm very interested in making a 6.1 surround sound system from a couple of sets to be run off a seperate amp but need to know if adaptors are available for the strange input connection on the sub.
Many thanks
Old 06-01-2004, 10:04 PM   #9 (permalink)
The inputs are via 3.5mm stereo jacks one for the front and one for the rear. The sub reproduces all the deep bass from these and then sends the rest of the signal to the sats. So if you get a single phono to 2 phono adapter and a 2 phono to 3.5mm stereo adapter you could plug the combined lead into the controller of the z560. It'll work but what isn't clear is whether not plugging the sat speakers in will do any harm. I can't see how it can but the manual provides almost nothing to help. In terms od output the sub has bested my mission 70ASE and an Eltax Atomic 10.2 that I'm currently playing with. However, it doesn't give the tight, clean bass that most enthusiasts crave.
The sats take bare wires or banana plugs so I slotted them into my mainsystem and tried them as a stereo pair with a Servo 15. The worked surprisingly well like this and I may even use 2 of them as rear surrounds in my bedroom system.
Overall for £60 I'd buy them and give them a try.
Old 06-01-2004, 10:35 PM   #10 (permalink)
monkeynuts's Avatar
well i've bought a 2nd set and set 3 fronts up with my Marantz SR6200 amp and left the PDR-12 set up with usual surrounds and they sound very good for less than a tenner each!
I'll have a go at working out wiring up the sub as i really want the system to work out as a cheap surround sound setup for my girlfriend to connect up to her dvd player.
Can you buy a 'female' 3.5mm connector? i have a 3.5mm to 2 phono lead that i used to connect a portable MD to amp to get me started....
Thanks again
Old 07-01-2004, 8:05 PM   #11 (permalink)
Thanks: Gave 0, Got 6
Thanks for posting this offer, and with your advice I have a purchased a set. However not sure if the built in sound on the motherboard does them justice as they are sounding a bit too bass(ey), even with the sub turned right down.
Has anyone got any suggestions on a decent sound card to go with these speakers, hopefully not expensive as I am still suffering from the 'what the heck have you bought now'.
Hope you can help.
MalcolmD is offline   Reply With Quote
Old 07-01-2004, 9:18 PM   #12 (permalink)
I'm using a Creative Labs Soundblaster Platinium Live 4.0 sound card. Should be able to pick one up on ebay for £20-£30 (more if you want the breakout connection box (fits into a 5.25 bay). I think this sounds pretty good and I was pleased with it even at its new price of £130 a few years ago.
Old 07-01-2004, 9:54 PM   #13 (permalink)
pardip
Posts: n/a
Have you got a code for these speakers?
Old 08-01-2004, 2:13 PM   #14 (permalink)
Mark Ward's Avatar
Monketnuts wrote:-
I haven't tried it yet but I've the bits and can't see whay this won't work.
Both of the Speaker system mini-jacks
into
Maplins Stereo headphones mini-jack splitter
into
Maplins Stereo Mini-jack(Female) :Mini-jack(Female)adapter
into
Mini-Jack to 2 RCA (Phono)
into
2 RCA:1 RCA adapter
I happened to have most these leads lying around anyway but should work OK. I don't think that lot would all that much in Maplins.
I'd point out that this is a temporary setup intended for the living room until I locate a reasonable sub for around £200.
Mark.
Mark.
I ♥ Linux
Old 08-01-2004, 5:53 PM   #15 (permalink)
monkeynuts's Avatar
Mark,
Thanks for the advice, i have bought a Stereo Mini-jack(Female) --Mini-jack(Female) adapter for £2 from my local audio/video shop and found a 3.5mm--female phono socket lying around that i can connect the subwoofer lead to directly.
Works a treat and sub seems to come to life with the signal from DD/DTS from my AV amp. not quite up there with my PDR-12 but more than good enough for my old man.
Thanks again
Sam
400w, logitech, sound, speakers, surround, z560
