Go Back   AVForums.com > Bargains and Discount Codes > Home Cinema Hardware Bargains and Discount Codes
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 02-01-2004, 5:31 PM   #1 (permalink)
Mark Ward's Avatar
Thanks: Gave 87, Got 11
Maplins Digital SPL Meter £34.99 until 24th Jan 04
Maplins Digital SPL Meter £34.99 until 24th Jan 04 in their BIG SALE brochure
I use one of these all the time and love it.
Order Code TB57M
Mark.
I ♥ Linux
I use Linux for:- CCTV (Zoneminder), Telephones (Asterisk), Raid Storage (UnRaid) & HTPC (LinuxMCE - When I finally get it working).
Next project:- Linux Home Automation (probably using MisterHouse)
Mark Ward is offline   Reply With Quote
Old 03-01-2004, 11:22 AM   #2 (permalink)
Thanks: Gave 49, Got 107
Are the specs on Maplins site right - it only measures down to 300 Hz ? So no good for sub setup then ?
Mark.
Pioneer 2011, Tannoy R3s, Tannoy RC, Tannoy M2s, SVS PC-Ultra13
Buckster is offline   Reply With Quote
Old 03-01-2004, 12:02 PM   #3 (permalink)
Mark Ward's Avatar
That's very strange, I haven't seen that before. I use mine to calibrate sub for BFD and get measurements as low as my sub goes.
Can anyone else shed any light on this? The manual doesn't mention any frequency limits.
Mark.
I ♥ Linux
Old 03-01-2004, 12:03 PM   #4 (permalink)
ailean
Posts: n/a
This got me too. I'm not sure what the spec means in this regard as mine certainly reads test tones well below 300Hz. My guess is that the calibration might only be acurate down to 300Hz.
Old 03-01-2004, 12:13 PM   #5 (permalink)
i still advise that an analogue meter is a better idea..... if you have levels jumping about, then a digital one is much harder to use
ad
buns is offline   Reply With Quote
Old 03-01-2004, 12:33 PM   #6 (permalink)
Zor
Zor's Avatar
I also have one of these.
Manufacturers Spec Also did not realise the 300Hz thing.
Regarding digital meters you can change the response time if the signals are jumping around.
F.A.B.
Zor is offline   Reply With Quote
Old 03-01-2004, 12:45 PM   #7 (permalink)
ok...... but if you alter the response time..... then you are limiting its accuracy!
I guess for most the digital will be fine though, but if you are doing things like trying to locate a sharpish peak, analogue is the only choice
ad
24th, digital, jan, maplins, meter, spl, £3499
