3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema General Chat
Latest AVForums Movie Reviews
Last King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray Review
Vengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray ReviewJulie & Julia Blu-ray Review
Thread Thread Starter Forum Replies Last Post
choice of 3 tvs samsung le32a56c, sony 32v4000 and the 32" lg 5700 need help jason8472 Which TV Should I Buy? 34 06-03-2009 9:32 PM
Why sky india support has to be scrapped,my HD install woes toz66 Sky HD 11 04-03-2009 1:47 PM
Loud noise from Amp when subwoofer turned on gf Design AV Amplifiers and Receivers 4 04-03-2009 10:02 AM
Trying to get my Pc to work with surround sound Amp via Optical cable sushi_ Sound Cards and Internal Audio Devices 1 04-03-2009 9:25 AM
Old 04-03-2009, 9:26 AM   #1 (permalink)
Thanks: Gave 21, Got 0
Awful picture Sony KDL-40V4000 & SKY+: help neeed
I just connected my Sony KDL-40V4000 to SKY+ by Scart cable (it works on AV1). i HAVE SET UP 16:9 / RGB / Scart on, but the picture qaulity is poor - fuzzy around lines and writing and extremely pixaly on dark / balck scenes (hard to watch), brigheter scenes are better but still not what i expected.
Please can somone advise how i can rectify this as i was expecting a very sharp clear picture
Many thanks
techstar* is offline   Reply With Quote
Old 04-03-2009, 9:34 AM   #2 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,215
Re: Awful picture Sony KDL-40V4000 & SKY+: help neeed
First off do remember you are watching a SD picture but you should get a fairly reasonable one all the same. Do make sure the Scart socket you plugged into on the Tv is RGB, not all Scart sockets on a TV are.
The only other weak link is the Scart cable and this can have a very adverse affect on picture quality.
A lot of supermarket "Gold" Scarts, or supplied ones are pretty rubbish to say the least.
Look for Scart cables from the likes of QED, IXOS, Thor etc.
BUT all said and done a Scart cable could cost £15-25 which is not too far short of of a new SKY HD box.
Your Freeview picture should be very good.
Andy98765 is offline   Reply With Quote
techstar* (06-03-2009)
Old 04-03-2009, 10:02 AM   #3 (permalink)
How do i check if the the AV1 socket on the TV is RGB - The user manaul does not clarify this?
http://pdf.crse.com/manuals/3298969611.pdf
Old 04-03-2009, 10:06 AM   #4 (permalink)
Thanks: Gave 17, Got 305
As Andy said, remember that you're watching SD material. It's naive to assume that you'd get a perfectly clear image on an HDTV screen from an SD source. The TV is designed to give the best picture from HD material - and I'm sure if you hooked up a Sky HD box, PS3, xbox 360, etc that it would be.
Did you check out the TV first at a local Comet or whatever to see how it handled SD content? I just wondered if you'd seen the TV in action before, after saying how you'd expected a crystal clear image.
Also, have you tried changing any of the TV settings, or are you just using the factory settings? All the Sony's I've owned are set to the "LIVE" picture mode where the brightness and various other settings are cranked up to the max.
"I'm gonna give you to the count of 10, to get your ugly, yellow, no-good keister off my property...before I pump your guts full of lead!
StevieBuck is offline   Reply With Quote
Old 04-03-2009, 10:12 AM   #5 (permalink)
Thanks guys,
I will play around with custom settings and see if this makes a difference.
PS3 and DAV DZ260 is being set up today so i will also compare picture on these.
Do you know what settings i should change on the PS3 / TV for optimal viewing and suuround sound for these?
Many thanks
Old 04-03-2009, 10:13 AM   #6 (permalink)
Check out the specifications listed on p35 of that manual - it shows that AV1 and AV2 (i.e both scart inputs) are RGB capable.
As long as the Sky box is set to RGB you shouldn't have a problem.
RGB didn't seem to work on my Sky HD box until I enabled 'scart control' as well in the Sky box's options - not sure why though.
Old 04-03-2009, 10:16 AM   #7 (permalink)
stevenk4563's Avatar
Thanks: Gave 0, Got 8
Try using the settings as shown in the screenshots on this page. Should be a big improvement over the standard settings.
Sony KDL46W3000 :: Onkyo TX-SR606 :: Mordaunt Short Alumni :: PS3 :: Sky HD :: Wii
stevenk4563 is offline   Reply With Quote
Old 04-03-2009, 10:24 AM   #8 (permalink)
You shouldn't need to change much for the PS3 - as long as it's connected with an HDMI cable the picture should look excellent. I'd make sure you have it set to 1080p in the PS3 options though. If it's the first time you're setting up the PS3 it will check what your TV can handle anyway and set this for you. Otherwise just go back into the options to set it manually.
The DAV-DZ260 has an optical input for 5.1 surround from an external device. If you don't have one, I'd suggest you buy an optical cable and connect the PS3 directly to the DZ260. Make sure you enable the optical output for in the PS3 menus. Again, it will ask you to set this up during the intial setup if it's your first time using it.
Also, make sure the audio output in the 'BD/DVD options' for the optical connection is set to 'Bitstream' as opposed to Linear PCM. Finally, check the audio output formats that are enabled, make sure that only the Dolby Digital, dts and the 2 channel Linear PCM options are selected. The DZ260 cannot handle multi-channel Linear PCM so all of the 5.1 and 7.1 settings should be disabled.
Edit: - I forgot you said you had Sky+. This has an optical output as well which you can also hook to the DZ260 so you can watch (well, listen to) TV through it. If you have Sky movies you will get 5.1 sound from movies this way, or stereo from the other channels. Since the system only has one optical input though it may be worth your while buying an optical switcher as well
Old 04-03-2009, 10:40 AM   #9 (permalink)
Thanks: Gave 243, Got 473
Just to add, I have two Sony LCD TV's a 40" & a newer 46". Both TV's were hideous picturewise on the out of the box default settings.
Sony KDL46W5500, Sony STRDA2400ES, Sony RDRHXD870, Sony BDPS550, Sony TDMIP50, Samsung Sky+HD, XBox360+HD DVD, Sony VCR, 4 X Tannoy F4 Customs + Tannoy FC Centre + Tannoy TS10 Sub, Logitech Harmony ONE
Yamaha YZFR1 MY STUFF
KDL40P3020+BD35+HTPC+XBox360, KDL46D3500+DAV-SC8(Bedroom)
William YZF-R1 is offline   Reply With Quote
Old 04-03-2009, 10:57 AM   #10 (permalink)
Conspicuous Member
davepuma's Avatar
Thanks: Gave 172, Got 1,525
Every flat panel isn't that great on SD even £muchos Pioneers IMHO. LCD is especially poor. I used the settings from hdtvtest (or similar) for my parents Sony LCD (think it's same one as yours) and it did improve the pic but in the end, they're designed for HD not SD and blowing it up to 40" just highlights poor feeds even more.
AV Setup Panasonic TH42PZ81 | Hitachi PJTX200 | Toshiba HD-EP35 | Squeezebox 3 plus itouch/ipeng controller | Xbox360&PS3 | Sky+HD | Denon AVR3805 | Focal Chorus 816V/806V/CC800V | SVS PB1-ISD | Harmony One |
davepuma is offline   Reply With Quote
Old 04-03-2009, 11:40 AM   #11 (permalink)
SKY also gives the option to change picture quality - contrast etc - should i keep this as standard or also adjust these as well as the tv's. If so please can you reccomend to what
Thanks again
Old 04-03-2009, 1:13 PM   #12 (permalink)
I keep mine on the default setting (contrast/brightness=medium I think) and then use the TV settings to fine tune.
Old 04-03-2009, 5:48 PM   #13 (permalink)
Thanks: Gave 7, Got 5
Whilst this may be true in part, it doesn't really account for the fact that the OP's dark scenes are almost unwatchable!
I have a 50" Sony (Rear Projection) HDTV, and also have Sky+, and my picture is pretty good - obviously nowhere near HD quality, but still pretty good...
I suggest changing the TV settings until you get a better picture
nik_kosy is offline   Reply With Quote
Old 06-03-2009, 10:24 AM   #14 (permalink)
could it be that i am sitting too near the tv. i currently sit about 6.5 ft away from the screen? or could their be interefence from sound sytem / sky etc.
I also cinnected this tv to sky via rf and the picture wuality was worse - so prob not a scart lead issue.
odly though i have sky connected to a sony bravia 30" via rf in another room at the picture their is so much clearer?
Your advice is much appreciated
Many thanks
Old 06-03-2009, 11:54 AM   #15 (permalink)
It won't be that you're sitting too close, as I sit the same distance away from my 50"
I would still be looking at the various TV and/or Sky settings if I were you...
awful, kdl, neeed, picture, poor picture, poor quality, sky, sky +, sony, sony lcd kdl40v4000
Copyright © 2000-2010 M2N E. & O. E.
