Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Kenwood 7200 speed pulse/signal wire? donovan2123 In Car Entertainment (ICE) 2 06-05-2009 3:20 PM
I want to run one HDMI cable to my panny and have my Sky+, Wii & PS2 connected OBee1 HDMI Cables and Switches 12 06-05-2009 8:11 AM
Old 05-05-2009, 11:18 AM   #1 (permalink)
Thanks: Gave 1, Got 1
Running Wires behind plasterboard?
Hi, i am looking to have a wall-mounted TV in the center of my wall, and have the HDMI, Power, VGA cable run from the loft to this upstairs spare room, (this wall is between us and the neighbours) can anyone suggest the best way to go about this?
I am thinking either channel out a whole line from center of the wall up to the ceiling so cut out the plaster say 1inch thick, run the wires, and then fill the channel with Filla and then wall paper.
or cutting a hole say 2inch diameter, and poking something in and hoping that it arrives somewhere in the loft and thus pulling through all wires.
help!
John180 is offline   Reply With Quote
Old 05-05-2009, 8:15 PM   #2 (permalink)
Thanks: Gave 0, Got 6
Re: Running Wires behind plasterboard?
As long as the wall is dabbed, make a hole near the ceiling on the wall so you can pierce through the ceiling a bit easier, hole by the tv, shuv something up, fingers crossed it gets into the loft, use a sturdy draw wire / string to pull them down / up.
a lot less dust and mess and making good than chasing the wall
Sacred09 is offline   Reply With Quote
Old 05-05-2009, 8:37 PM   #3 (permalink)
If house is a timber kit and this is a fire wall between you and neighbour ( Not Dot and Dab ) Gyproc plank and plasterboard you should not be cutting into this wall at all as it will effect the fire rating between the two properties.
Coulter51 is offline   Reply With Quote
plasterboard, running, wires
