Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Which PCIE graphics card is best for my new Dell 1920x1080 monitor? dlittlewood Graphics Cards and Internal Video Devices 2 01-05-2009 7:52 PM
Computer monitor as dvd display AVJames Monitors, Webcams and External Video Devices 2 01-05-2009 4:37 PM
Old 02-05-2009, 11:46 AM   #1 (permalink)
Saldawop's Avatar
Thanks: Gave 85, Got 236
22" Monitor Wall mount
I have a 22" monitor.The base takes up a lot of room so was thinking of wall mounting. The wall in question is ,I think,plastered breeze block. Will it work? Will I need special fixings?
PSN ID - LionOfTheSouthUK
Xbox 360 Gamertag - LionOfTheSouth
Saldawop is online now   Reply With Quote
Old 02-05-2009, 2:38 PM   #2 (permalink)
Thanks: Gave 15, Got 40
Re: 22" Monitor Wall mount
you should get all fittings you need with the wall mount. yes it will be ok on a breeze block wall.
le46a557p, ht-z310, sammy skyhd, 360 elite, sammy R700.
welshcraig is offline   Reply With Quote
Old 02-05-2009, 7:47 PM   #3 (permalink)
Member 45084's Avatar
Thanks: Gave 0, Got 13
Maybe this selection of wall mounts might help your installation.
TV Wallbrackets up to 26"
Regards
Roddy
Member 45084 is offline   Reply With Quote
monitor, mount, wall
Copyright © 2000-2010 M2N E. & O. E.
