Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
DaveyB's HTPC & 7MC upgrade/build Thread Daveybryce Home Cinema PCs 380 17-11-2009 8:44 AM
Ninja 12's Silverstone CW02 HTPC ninja 12 Home Cinema PCs 121 21-10-2009 10:05 AM
The 'Ba's' Dedicated Cinema Build ashcurrie Home Cinema DIY 65 15-08-2009 1:25 AM
My final HTPC build, advice and questions please cs3007 Home Cinema PCs 37 05-05-2009 9:12 PM
Node o Build - How many plugs can I have on one adaptor? newstuart Home Cinema DIY 4 01-05-2009 7:04 PM
Old 02-05-2009, 11:01 AM   #1 (permalink)
Thanks: Gave 368, Got 63
New False chimney build
Hi all before i go ahead i'd like to collect as much info as possible. Our living room is quite narrow so this false chimney/integrated TV & equipment will same alot of space
Before i start here is the room as it stands:
And here is a first draft mock up (fireplace will be replaced with equipment)
Now the main info i need is how far can i bring this out, i really want to make it has slim as possible for space saving but don't want it to be crapped for equipment.
Now the deepest piece of equipment will be the amp (not purchased yet) This will be 45cm so will 8 cm be enough clearance at the back for the cabling?
Equipment will be:
Amp (Denon)
Sky HD
WDTV media box
Toppy PVR
DVD player
Many thanks and please jump in with any other suggestions.
Cinema room spec: [eyes] Planar PD7010 - [ears] Samsung HTZ310R - [Heart] PS3
My Cinema Room Build...
deefadog is offline   Reply With Quote
Old 02-05-2009, 3:38 PM   #2 (permalink)
berkeley384's Avatar
Thanks: Gave 64, Got 79
Re: New False chimney build
Hello Mate
I think that your Chimney is going to have to come out by around 50cm if you want to house the amp which in my opinon is too deep.
If I were you I would keep to the original plan of making it as slim as you can and look at other options for the where to put the kit
My Chimney is about 23cm deep, I think more than 30 will be too much
Steve
Denon 3806 / Toshiba 37X3030 / BK XLS300 / MS Genie Surround System/ PS3 / Sky HD/ iPhone
All Controlled by Logitech Harmony One & IR4PS3
berkeley384 is offline   Reply With Quote
deefadog (03-05-2009)
Old 03-05-2009, 10:30 AM   #3 (permalink)
Thanks, Yes i agree, 35cm would be ok, that would house the other equipment as well, but it's the amp that's the offender. Most amps are rather deep, i'll see if i can find one that's around 30cm deep!
Any suggestions more than welcome
build, chimney, false
