Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Wii cable discussion/advice thread. Composite/ Component/ RGB Scart/ VGA py6km Wii 940 17-11-2009 9:14 PM
Suggestions for Centre speaker to match XTZ 99.25 please: Dazzor Speakers 11 21-05-2009 10:30 PM
Aerial Cable via Ethernet fisherprice Freeview 3 30-04-2009 7:59 PM
At what point do you set speakers to "large" in amp settings? Prize78 Speakers 18 30-04-2009 10:03 AM
V+ Box fitted today, but no HDMI cable? few cloudy Virgin Media 13 29-04-2009 3:19 PM
Old 29-04-2009, 3:41 PM   #1 (permalink)
Thanks: Gave 26, Got 41
Speaker Cables laid into wall, permanent?
Still planning my new AV setup and wondering what to do with the cables. I plan to put them into the wall, but just wondered how other people have done this.
Should I try to put the cables in a larger channel so they can be pulled back and changed at some point in the future, or do they just get plastered over and become a permanent fixture?
My problem with channeling so the cables can be pulled back is that I have solid floors, no floorboards to run the cables under. So I either have to put the cable between the floor and carpet, or channel it into the roof.
Any thoughts are appreciated.
conan is offline   Reply With Quote
Old 29-04-2009, 4:21 PM   #2 (permalink)
Thanks: Gave 12, Got 8
Re: Speaker Cables laid into wall, permanent?
Can you put the cables in a piece of conduit (Mine are in 40mm waste pipe)?
Also put in a draw string so that you can pull additional cables through as and when required.
TV: Toshiba 32WL66 AMP: Onkyo 605 SOURCES: V+, Pioneer DV400, Vista Media Centre PC running Media Portal SPEAKERS ZONE 1 (Lounge): Jamo A102's SPEAKERS ZONE 2 (Kitchen): 6.5" 100W Ceiling Mounted
pmanson is offline   Reply With Quote
Old 29-04-2009, 5:29 PM   #3 (permalink)
Nice idea, that should work fine, love the idea of the drawstring
cables, laid, permanent, speaker, wall
