Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Studs 44" apart... need mounting advice blaiel3 Flat Screen TV Brackets and Mounts 4 24-04-2009 9:29 AM
Stud wall bracket mivec Flat Screen TV Brackets and Mounts 3 31-03-2009 6:22 PM
Lg 32pg6000 Stud wall mount Marcus D Flat Screen TV Brackets and Mounts 8 13-03-2009 3:12 PM
False chimney, would you mount tv on the stud frame or wall ? oosyadaddy Home Cinema DIY 8 02-03-2009 10:29 PM
Old 26-04-2009, 11:44 AM   #1 (permalink)
MacReady's Avatar
Thanks: Gave 211, Got 60
How to use Makita Stud Detector?
Sorry if this sounds like a dumb question, but I have just borrowed a Makita metal/wire/stud detector from someone and I dont have the faintest idea how to use it
I need it to find somewhere suitable in the living room ceiling for a projector mount and a manual projector screen.
I have the detector set to find studs but it seems to be beeping pretty much all the time?
Cany anyone tell me what I am doing wrong or if there are any on-line instructions for this things.
My HC set up
My Kit Samsung LE40M87 LCD TV - Onkyo TX SR606 AV Receiver - KEF 2005.2 Speakers - Xbox 360 Elite - XBox HD DVD - Sony PS3 60Gb - Nintendo Wii - Sky + - Sanyo PLV-Z3 - Panoview 6' Screen
XBox Live Gamertag - EndoViper PSN - Endo_Viper
MacReady is offline   Reply With Quote
Old 26-04-2009, 4:19 PM   #2 (permalink)
Thanks: Gave 16, Got 105
Re: How to use Makita Stud Detector?
Your doing nothing wrong, the detectors are a waste of space I have tried using one and ended up taking it back for a refund.
You are better off using a very fine screwdriver and putting holes in the ceiling to find the joists. Once you have found one they will be around 16" centres or 400mm.
John...
27neth is offline   Reply With Quote
Old 26-04-2009, 4:23 PM   #3 (permalink)
Thanks: Gave 168, Got 82
i had one, and if the power socket on the wall i was testing was switched on id get millions of false beeps, as soon as i turned the wall sockets off on the wall it worked fine.
xbox tag fragdude, currently playing PGR4, Halo3, Team Fortress 2 and COD4 PSN Fragdude, currently playing motorstorm, RFOM
Trading feedback will now only be left when people leave mine, too many cant be arsed to return feedback.
mr ooops is offline   Reply With Quote
Old 28-04-2009, 7:58 PM   #4 (permalink)
Thanks: Gave 2, Got 0
Same here, worked fine once the electricity was off (the meter was on the same wall).
FoxForceFive is offline   Reply With Quote
Old 29-04-2009, 1:05 PM   #5 (permalink)
MacReady's Avatar
Thanks for the replies. Kind of figured it was not that great a peice of kit as I seemed to be getting beeps all the time....even if it was knowere near the wall!
I ended uyp sorting it last night though. was giving the stud detector another rty and, in between all the random beeps, there was one area in the right vacinity where I wanted to mount the projector that kept giving a beep.
I took the detector away and gave the ceiling a gentle tap in that area to see if it sounded different......and about two inches to the left a couple of the nails holding the plasterboard to a stud popped straight out.
So, thanks to the shoddy build quality on new builds, all I needed to find a stud was my fist :-D
My HC set up
detector, makita, stud
