Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Sky HD - Switch HDMI power command? deefadog Sky HD 14 02-05-2009 10:12 AM
The Latest Ad hammerbenj iPhone App Store 6 22-04-2009 10:36 PM
PS3 won't switch on....help Addicted 2 PS3 PS3 8 21-04-2009 12:09 AM
Old 20-04-2009, 1:44 PM   #1 (permalink)
Thanks: Gave 75, Got 39
Adding an inline switch to rope lights?
Someone recommended these Rope Lights I think the're LED:
Duralite Rope Lights
I understand they have to be fitted with a plug to be switched on/off but can some kind of inline switch be added so I wouldn’t have to keep getting to the mains to turn the power on and off?
Idea was im going to have them behind the bed headboard so they glow onto the backwall, so i wanted a switch just by the bedside so i dont have to get up to switch them on and off
any ideas whether this can be done and what i need to buy?
VAMOS DAN is offline   Reply With Quote
Old 20-04-2009, 1:56 PM   #2 (permalink)
Thanks: Gave 35, Got 41
Re: Adding an inline switch to rope lights?
Hi might be cheaper and easier to just buy a remote control plug socket and control like the home easy range which can be bought from B&Q. I have my lights controlled by one in my floating wall.
Hope this helps
KobeoneHD
Lounge: Samsung PS50B430 - Harmony ONE - Samsung BD -P1500 - Toshiba HD- EP30 - Sky HD - Mordaunt short 302's and 304C - Sony STR-DG910 - Mordaunt Short Alumni 9 sub - Mark Grant and QED cables - Apple airport express - WII
Bedroom: Samsung LE32R8 - Sky+ - KEF ci50r's - QED micro cables
KobeoneHD is offline   Reply With Quote
VAMOS DAN (21-04-2009)
Old 20-04-2009, 2:14 PM   #3 (permalink)
Hope this helps
KobeoneHD
Good alternative although im guessing this will cost alot more than just adding an inline switch?
Old 20-04-2009, 9:27 PM   #4 (permalink)
Thanks: Gave 15, Got 5
Vamos Dan with the B&Q range you just plug it into the wall socket and then plug the plug for the rope light into it. You can then use the remote control to turn the switch on and off. The range is quiet reasonably priced.
Or there's this option which is also part of the home easy range and quiet reasonably priced...
Home Easy Remote Single Wall Switch & Socket Kit HE317 on eBay, also, Home Automation, Gadgets, Consumer Electronics (end time 28-Apr-09 00:13:18 BST)
theodotcom is offline   Reply With Quote
Old 20-04-2009, 10:42 PM   #5 (permalink)
Thanks: Gave 2, Got 7
Looks like this is the sort of thing you are after - cheap as chips too!
In Line Cord Switch
fredd500 is offline   Reply With Quote
Old 21-04-2009, 12:24 AM   #6 (permalink)
In Line Cord Switch
The home easy range does look good and i'll defo look into it for use with other projects so thanks
The inline chord was the exact thing i was after so i'll give it a go when i go and pick up the rope lights from tlc tomorrow.
Many thanks guys
adding, inline, lights, rope, switch
