Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Overclocking E6400, getting mixed temp readings? Bionic Monkey Desktops and Servers 4 03-05-2009 9:01 AM
Denon 1909 doesn't mix DVI and Analog audio almo81 Denon Owners' Forum 5 15-04-2009 9:43 PM
Mixed up power cables for KRP-600A screen and box!!! shaffers17 Plasma Televisions 5 15-04-2009 7:29 PM
mixed cables in routes ? Jamster1 Home Cinema DIY 5 15-04-2009 11:50 AM
Old 16-04-2009, 7:49 PM   #1 (permalink)
Question Should I mix accoustic insulation and normal insulation to absorb sound?
I have bought some accoustic wool (60kg/sq m 100mm) and have started to fill the joists under my floor. The floor already has standard thermal insulation.
1. Is it worth me putting the standard wool on top or underneath the accoustic wool? Any advantage?
2. Can I cover all the cables with the accoustic wool and/or the standard wool?
I'm planning to put sound mats on top of the chip board floor in an attempt to stop sound travelling from a ground floor room into a bedroom and vice versa.
Hope someone can help me!
AL
hitchiner is offline   Reply With Quote
Old 17-04-2009, 9:28 AM   #2 (permalink)
Thanks: Gave 16, Got 2
Re: Should I mix accoustic insulation and normal insulation to absorb sound?
I've done a similar thing. My sons bedroom is right above the cinema room so I bought a load of wool and stuffed two layers between the joists. Then under his laminate floor I put some acoustic matting.
It does make a difference but tbh, you can feel the sub through the whole house when it's on anyway
I would imagine there'd be no problem laying the wool on top of the insulation.
Bob.
Samsung LE46A786 | Onkyo TX-SR705 | SVS SBS-01 | BK Electronics Monolith-DF | Sky+
Dodgy Bob is offline   Reply With Quote
Old 17-04-2009, 12:37 PM   #3 (permalink)
Did you fill the joists to the top? Or is it worth leaving some kind of gap so the insulation - accoustic or normal - doesn't touch the floorboard and 'transmit' sound???
I'm going to do a course in all of this stuff!!! Must be simple all of this??
absorb, accoustic, insulation, mix, normal, sound
