Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Sony HTIS100 home audio system UMAR 3:16 All-in-one Systems 989 Today 1:07 AM
Gibbs Home Cinema gurpswoo1 Home Cinema DIY 29 27-07-2009 5:48 PM
Sony KDL40W2000 fault - Help / Advice wanted on warranty or repairs. Scapegoat LCD Televisions 42 06-05-2009 6:20 PM
IR extender advice monksy74 Remote Controls 8 16-04-2009 6:36 AM
Old 14-04-2009, 8:50 PM   #1 (permalink)
Thanks: Gave 1, Got 7
Home cinema project, advice needed
We have just finished building an extension and plan on making a home cinema room.
We have decided we want either in-wall speakers or ceiling speakers.
The advice i would like is, which would be the better option for sound, what the best make/type of speakers to use, where to buy them from and any other info that would be of help
dj_padd is offline   Reply With Quote
Old 14-04-2009, 8:52 PM   #2 (permalink)
Thanks: Gave 89, Got 87
Re: Home cinema project, advice needed
Have you had all your cables put in ready ?
Denon 3806 Receiver - Denon 2910 DVD - Monitor Audio RS6 / RSLCR / RSFX - SVS PB12 Plus - Panasonic PT-AE3000E - Beamax 92" Screen - Pioneer Kuro PDP-4280XD - Panasonic DMP-BD60 - Harmony One
Kevo330 is offline   Reply With Quote
Old 14-04-2009, 8:56 PM   #3 (permalink)
No not yet
Old 14-04-2009, 8:59 PM   #4 (permalink)
Ah ok, if the interior still needs to be finished, lined and plastered etc, it's gonna make thing's much simpler for you.
Old 14-04-2009, 9:02 PM   #5 (permalink)
Yeah, all the interior still needs to be done, the walls are just brick at the moment
Old 14-04-2009, 9:09 PM   #6 (permalink)
I remember when my extension was at that point. It was a really exciting time, planning for all the cabling, power points, mounting supports etc.
Old 14-04-2009, 9:24 PM   #7 (permalink)
Ive got all that to look forward to, the hardest thing is choosing what kit to have, i have no idea about this home cinema stuff
Old 15-04-2009, 9:42 AM   #8 (permalink)
Thanks: Gave 603, Got 516
Depending on your budget I would go for inwalls, simply so you can position them at a better height for listening.
just my opinion but I can`t help thinking that ceiling ones are more for surround sound rather than dedicated 5.1 listening to movies stuff.
Which are the best, well sit down here.................................
How big is your budget my outlay so far for my inwalls if you were to buy them new today is around £4.5k then you need some good amplification to make them work, Oh and a couple of decent subs £2.5k.
So thats around 9 grand, then you need.....................................
So in other words we need to know your budget, room size and if you have any equipment already.
You can see mine in my thread somewhere but these are really very high end speakers so you might not need/want to go this way.
One of the big problems with inwalls in the impossibility to demo them as well, I was thinking initially about Monitor Audio CP Golds or Kef 9000`s at the time I was looking for some but simply on not being able to listen to any went and got these MK`s and am I glad I did, they are unbelievably brilliant but should be shouldn`t they
good luck and keep us posted Al
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
Old 15-04-2009, 6:19 PM   #9 (permalink)
The extension didnt even cost £9000
Equipment: i have is a ps3 for blu-ray, and a tv thats it
Budget: about £1000 which needs to buy speakers so i can have a 5.1 system and an amp and all the wires and anything else i might need
Old 15-04-2009, 6:27 PM   #10 (permalink)
How big is the room ?
Can you consider any alternatives like wall mounting the rears etc ?
Old 15-04-2009, 6:56 PM   #11 (permalink)
The room is approx 18ft x 16.4ft and i would like to have all the speakers in-wall or in-ceiling mounted
Old 15-04-2009, 10:42 PM   #12 (permalink)
Docta teef's Avatar
Thanks: Gave 30, Got 19
I would doubt that you would get an in wall or ceiling system for a grand i'dgo for wall mounted and cut some in walls into the plaster at a later date
Docta teef is offline   Reply With Quote
Old 15-04-2009, 11:19 PM   #13 (permalink)
Indecisive's Avatar
Thanks: Gave 19, Got 19
If you shop around and are willing to buy used equipment I think your £1k could get you what you need.
I am not suggesting you buy these, this was just a quick search......
Sonance Cinema System 2 THX In-Wall full 7.1 speakers. on eBay, also, Speakers Hi Fi, Home Audio Hi Fi, Consumer Electronics (end time 16-Apr-09 20:38:12 BST)
You could also check the classifieds on here for a good deal.
But NEW, I think you will find it hard to get a good sounding in-wall set-up for your £1k.
Good luck with your project
My Floating Wall Project - Come and see
Panasonic TH-50PZ81B / Denon AVR-3802 / Denon DVD-2800 / PS3 60gb / Wii / Virgin V+ / Kef KHT1005 / Harmony 1000
Indecisive is offline   Reply With Quote
Old 16-04-2009, 5:24 PM   #14 (permalink)
What would a more realistic budget be?
Old 19-04-2009, 2:48 PM   #15 (permalink)
Im having a mess about for the room design on sketchup, where in the room would be the best location for the tv?
This is what i have got so far
Home cinema project, advice needed-room.jpg   Home cinema project, advice needed-room2.jpg
advice, cinema, home, needed, project
