Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Software / Widgets potential for Tocco Ultra markdj Samsung Mobile Phone Discussions 0 12-04-2009 11:53 PM
The Cost of Blu Ray discs... Plummeting signs Blu-ray Movies and TV Programmes 25 12-04-2009 11:33 PM
What do on demmand movies cost? russ_e Virgin Media 6 10-04-2009 7:51 AM
Any new sub £1K receivers to potentially get excited about soon? G@zz@ AV Amplifiers and Receivers 12 08-04-2009 10:19 PM
Package Costs dpe Sky HD 3 03-04-2009 5:52 PM
Old 14-04-2009, 7:03 PM   #1 (permalink)
Potential Costs
Hi guys,
I have been looking through these forums lately and looking at some of the setups on here. They are awesome!!!
What I am looking for is maybe some help regarding costs etc. Costs of materials to do a floating wall, costs of equipment etc. Basically all the money i'd have to spend. A rough idea would be good.
JAMESTB is offline   Reply With Quote
Old 14-04-2009, 8:30 PM   #2 (permalink)
Thanks: Gave 89, Got 87
Re: Potential Costs
To construct a floating wall, you're going to need thing's like, timber studding - probably 3"x2", MDF, plasterboard, plaster, screws, nails etc. Plus all the tools to do the job.
When putting in the studding you will need to consider were your equipment is going to go, cable runs, power point etc. Also consider were the TV will sit as extra timber supports will be needed in that area.
Basically there is lots to consider apart from just building the wall.
Go to your local DIY store for the cost of materials and tools. It's impossible to give a cost for everything as you dont say what you want.
You'll need an idea of the size of wall to be built so that you can cost your materials etc.
Kev
Denon 3806 Receiver - Denon 2910 DVD - Monitor Audio RS6 / RSLCR / RSFX - SVS PB12 Plus - Panasonic PT-AE3000E - Beamax 92" Screen - Pioneer Kuro PDP-4280XD - Panasonic DMP-BD60 - Harmony One
Kevo330 is online now   Reply With Quote
Old 15-04-2009, 7:43 AM   #3 (permalink)
Magslad's Avatar
Thanks: Gave 145, Got 145
Re: Potential Costs
Originally Posted by JAMESTB View Post
Hi guys,
Somewhere between £500 and £100,000.
Seriously though - people will be happy to help but you do really need to give a bit more info about what you want. At the moment your thread reads "I want to do some stuff, how much will it cost?"
If you post with a bit more info you'll get far better answers, so think about:
- what AV equipment do you have already, and what are you thinking of getting?
- what room in the house? Plus will it be a dedicated cinema room, floating wall in existing living room, something else?
- are you going to do the work yourself or get someone else to do it?
- what sort of finish do you want? e.g. speaker cables chased into walls, surface conduit etc
Have a bit more of a think about what you're planning to do, post some more detailed questions, and you'll get some more helpful answers
Nikon D80; Nikon VRII 18-200mm & 50mm 1.8; Tamron 90mm Macro; Sigma 50-500mm EX DG
Onkyo TX-SR606; KEF 5005.2's; Panny 42PZ80B/BD30/DMR-EX78; NAD 304; Tannoy 607's; Harmony One
My loft conversion home cinema thread
Magslad is offline   Reply With Quote
Old 15-04-2009, 9:33 PM   #4 (permalink)
Thanks: Gave 0, Got 21
Re: Potential Costs
Just to clarify, a "floating wall" over there means a new wall placed in front of an old wall? This is a solid wall, not a false screen wall?
Thanks for the help
Ted White
Ted White is offline   Reply With Quote
Old 16-04-2009, 1:54 AM   #5 (permalink)
Thanks: Gave 12, Got 26
Re: Potential Costs
Thanks for the help
False screen wall,usually made out of mdf.Placed about 1 or 2 inches out from the wall using battons,wires etc can go behind.
velvitjester is offline   Reply With Quote
Old 16-04-2009, 3:06 PM   #6 (permalink)
Re: Potential Costs
Thank you for that. The wall is solid and rigid, then. Over here in the States, a "screen wall" is often a fabric covered wall with speakers behind it.
So your screen wall is rigid, covered in MDF. I assume the MDF is for additional density? Otherwise you could use plasterboard or less expensive plywood. Is that the case here?
Thanks again
Ted White
Old 16-04-2009, 6:53 PM   #7 (permalink)
Thanks: Gave 23, Got 41
Re: Potential Costs
over in the state mdf may be more expensive than plywood but not here bud.
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is online now   Reply With Quote
Old 16-04-2009, 6:54 PM   #8 (permalink)
Re: Potential Costs
I figured. Thanks. So the MDF is used to block sound or to have as a nail base?
Ted White
Old 17-04-2009, 2:08 AM   #9 (permalink)
Re: Potential Costs
Ted theres loads of pictures of floating walls.
The bottom this thread shows a floating wall
Gibbs Home Cinema
Although usually they would go from the ground up so you can hide your cables but you get the idea.
There are hundreds of floating wall threads on the forums
Groove's new lounge with floating wall build
Old 17-04-2009, 12:36 PM   #10 (permalink)
Re: Potential Costs
Got it. Wire hiding is the primary goal.
Thanks again. I'll check out the links you kindly provided
The pics say it all. THanks
Ted White
Old 19-04-2009, 3:59 PM   #11 (permalink)
Re: Potential Costs
I was thinking more of a floating wall to go over the chimney breast. But not on thats actually attatched to the wall. As I rent a house i dont want to be fixing something to the wall that i may hav to rip araprt when and if i move.
I was thinking that instead of screwing it to the wall, make sure it's structurally sound and maybe have weights at the bottom rear to stop it falling forward. If you know what i mean.
costs, potential
