Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
TIPS - TRICKS - IDEAS - FOR HARMONYS - ALL USERS - CHECK THEM OUT - now! Pincho Paxton Remote Controls 30 20-11-2009 2:12 AM
AV Forums staff. Any idea on when you'll be able to review new Samsungs and LGs gorman Plasma Televisions 51 04-05-2009 3:30 PM
European Championships (Only an idea at the moment) achapman14 PS3 Clans and Tournaments 50 30-04-2009 6:41 PM
LCD Full HD 1080p 32" TV under or close to £500,.. Any Ideas? longlivetheking Which LCD TV Should I Buy? 5 12-04-2009 9:38 PM
New to this, some ideas please. CatcherOnRye DVD Players 7 12-04-2009 6:54 PM
Old 13-04-2009, 5:25 PM   #1 (permalink)
Thanks: Gave 5, Got 2
Planning my install...advice & ideas needed/welcome!!
Hi all,
I've been reading these forums for a few months now and I'm nothing but impressed at the level/quality of some of the setups and it's inspired me to plan my own fake chimney breast install for when me and the rest of the family move into a new place in 6-8 weeks time.
I've been back and forward with the choice of gear to splash out on and I've settled on the following:-
Panasonic TXP37X10B Plasma (the viewing will predominantly be SD Sky and DVD so opted for this instead of full 1080p)
Samsung HT-Z310R upscaling DVD/5.1 System (I know this is entry level but it's a first system and I can currently get it for £114 from dixons.co.uk when I buy the Panasonic and I can always upgrade later on)
The 5.1 is going to be installed inside (and at the bottom) of a cupboard that will also house my dvd collection. Along with it will be my Sky+ box, Wii and a space for either a blu-ray player or a PS3 (if I can convince the missus that we need one!) to be added later on. The cables will all be run through a channel between the cupboard and the chimney breast so they're not visible.
I've already picked up a PowerMid IR link and a flood emitter which will go inside the cupboard to allow me to hide all the gear away from the little ones and still control it!
The power to the gear will come via a standby saver remote controlled 6-way that will let me turn it all off using my tv (or any other) remote.
For the 'bling' touches I've stolen a couple of great ideas from the site and I'm going to backlight the tv with the much-recommended Dioder LEDs from Ikea and I'm also going to be installing an uplighting channel around the top of the room (inspiration courtesy of MitsiTurbo - cheers!) and running the rear speaker cabling around the channel as well. The LEDs and the ropelight in the uplighting channel will be controlled by remote controlled plugs so I can control them without the need for visible switches (RADIPLUG, 3x Remote Control Mains Plug Sockets/Switches).
The few questions I have are:-
Will buying upgraded speakers and/or speaker wire make much of a difference to the sound coming from the 5.1 system or will the system itself limit the quality?
If anyone has the Ikea lights...is it possible to set them up to turn on to the same mode/colour each time or do you have to rotate through the different modes/colours each time? (I went for the multi-coloured version)
Lastly (and this one's a bit weird!), if anyone has the same Panasonic TV, could you possibly measure the depth of the sides before it turns in towards the middle (not the full depth of the tv, I've got that from the pdf manual on their wesite, just the side of it). I'm trying to figure out how far in the 'hole' behind the tv is going to need to be plastered so the holes/wires cannot be seen behind it!
Cheers in advance for any advice anyone can give me!
jamesk190 is offline   Reply With Quote
Old 13-04-2009, 5:33 PM   #2 (permalink)
Re: Planning my install...advice & ideas needed/welcome!!
To any of the moderators.....just realised I posted this in the Gallery not the DIY section....could it be moved please!?!?
Cheers,
jamesk190
Old 14-04-2009, 10:38 AM   #3 (permalink)
mabo's Avatar
Thanks: Gave 901, Got 730
Cheers,
jamesk190
Done.
Blu-ray and DVD Reviewer
The Best Blu-ray and DVD Resource AVForums Movie Reviews Bookmark it now!
My opinions expressed here are not necessarily those of the AV Forums or the associated websites
mabo is offline   Reply With Quote
Old 14-04-2009, 11:17 AM   #4 (permalink)
Indecisive's Avatar
Thanks: Gave 19, Got 19
I personally wouldn't bother upgrading the speakers in an all in one system although I would recommend upgrading the speaker cable if you plan to have the wires hidden in the walls etc. This saves having to chase everything out again for when you upgrade to a dedicated a/v amp and new speakers.
Good luck with your build, it will be worth the hard work as long as you are willing to put everything in to it.
My Floating Wall Project - Come and see
Panasonic TH-50PZ81B / Denon AVR-3802 / Denon DVD-2800 / PS3 60gb / Wii / Virgin V+ / Kef KHT1005 / Harmony 1000
Indecisive is offline   Reply With Quote
Old 14-04-2009, 5:45 PM   #5 (permalink)
@ Indecisive...
Cheers for the advice, the speakers aren't going to be chased into the walls, they're going to run around the room in the up-lighting channel so they're always going to be accessible. The cables between the av gear and the tv will run through a semi-removable channel (big enough to put a small wooden statue/carving we have on) that will run from the side of the cupboard into the side of the chimney breast and I'm going to have some sort of access panel on the side of the chimney breast to allow easy upgrading of the cables at a later date.
That said, if the cables are going to make a difference then it makes sense to get them now and run them around the room so I don't have to mess around changing them.
That's what I'll tell the missus anyway!!!
Thanks again
Old 14-04-2009, 5:45 PM   #6 (permalink)
@ Mabo....
Cheers!
Old 14-04-2009, 6:34 PM   #7 (permalink)
Thanks: Gave 35, Got 41
Good luck with it! What speaker cable are you thinking of? I can recommend QED silver anniversary XT from this website qed-cable-shop Silver Anniversary XT speaker cable
Very cheap and really makes a difference! Oh yeah dont forget the pics
KobeoneHD
Lounge: Samsung PS50B430 - Harmony ONE - Samsung BD -P1500 - Toshiba HD- EP30 - Sky HD - Mordaunt short 302's and 304C - Sony STR-DG910 - Mordaunt Short Alumni 9 sub - Mark Grant and QED cables - Apple airport express - WII
Bedroom: Samsung LE32R8 - Sky+ - KEF ci50r's - QED micro cables
KobeoneHD is offline   Reply With Quote
Old 14-04-2009, 7:05 PM   #8 (permalink)
KobeoneHD
Cheers for the recommendation but they're a little out of my price range!
Maybe when I look to upgrading to a dedicated av amp I can look at them
ideas, installadvice, needed or welcome, planning
