13-04-2009, 4:55 PM
#2 (permalink)
| | Member
Thanks: Gave 4, Got 10 | Re: Gibbs Home Cinema
Ok here we go I received the projector and front speaker on the same day, however like a 10 year old boy given chocolate by a naive parent and told not to eat it until after dinner, i just couldn’t wait so opened it up to test it on my light yellow wall.
The projector is so much bigger then you think but not too heavy: -
You can see how large it is compared to the chair. i hooked up the new front speakers to the my existing onkyo 565 amp. but used the standard sat speakers for the centre and two rears.
Amazingly you have to screw the floor plates to the bottom of the speakers yourself. impossible to do with a screw driver you need a drill. As it all black you are 100% gone to scratch the new piano surface as you can't see thorugh the painfully small screw holes. That’s a huge amount of packaging, I was rushing abit I guess. you can see the reflections on the wall from the high gloss finish. Here is some picture of it up and running sorry about the quality I'm not very good at it. |
13-04-2009, 5:15 PM
#3 (permalink)
| | Member
Thanks: Gave 24, Got 48 | Re: Gibbs Home Cinema
looks cracking mate.when you getting a screen up?
13-04-2009, 5:19 PM
#4 (permalink)
| | Member
The screens already here, im just finishing the floating wall off, which is a major pain to get it level. have pictures up later today or tomorrow.
13-04-2009, 8:14 PM
#5 (permalink)
| | Member
Here's some more pic:
i decided to make the electronics shelfs built into the wall instead of using a equipment stand outside, this was really just to save space but it looks alot better too.
The based is made a solid piece of wood, the side is made from thin plywood. the frame is made from 2" x 2" ply. the wires are fed from the top.
i also installed a 12v temperture controlled fan to remove the heat, i used rubber tap washer to redice vibrations: -
I know the finish is poor so I got some 25mm metal framing from Focus Do-It-All, what a rip off store but needed it quick.
Thats alot better  .
13-04-2009, 8:45 PM
#6 (permalink)
| | Member
The next stage is the projector mount.
Becasue i don't have loft access  I had to do my calculation to check where i needed the projector, from this I made a chunk out of the roof to see where the joist was.
Unfourtunantly the projector mount I ordered was not what I got and a new one would have taken 1-2 week minimum.
The minimum distance from the roof was 10 cm more, so i had to make my own supporting foundation further up in the roof.
You can see the support plank the mount is attached to running along the centre joists.
All I can say is thank good someone invented Lens Shift
The cut outs for the downlights are made and prep wiring is done.
As the mount was not the correct one the mount made it off centre, so i had to make another hole in the mount for the third support arm to correct this.
The projector is then temporarily mounted, positioned and leveled to check calcuations and make adjsutment. This will be bearings for the Floating Wall.
These are not universal mounts, whoever makes these claims need to check there definitions. |
13-04-2009, 9:05 PM
#7 (permalink)
| | Member
The next stage is the Floating Wall.
The frame is made by from 2" x 2" ply
The frame is contrusted from heavy duty corner brackets, overlapped are cut in half to improve stiffness.
Next the Floating wall was put in position and leveled correctly, this was done with several people of course.
It's then attached to the wall using 25 thick long screws, abit excessive but didn't want to worry about it falling off.
The Wall it was attached to was way out, so had to correct this to make it level.
I got 2 large MDF sheets and cut then equal in size for fitment.
It didn't matter if there was a line in the middle or didn't look flat as i a great idea to make it better.
Thats the construction complete for the floating wall.
14-04-2009, 12:38 AM
#8 (permalink)
| | Member
Thanks: Gave 1, Got 39 | Re: Gibbs Home Cinema
It's looking good..
Fatal mistake though, setting up the projector before you've finished the room..
What size is that room..and have you decided on the colour scheme yet?
14-04-2009, 9:51 AM
#9 (permalink)
| | Member
LOL,
Yeah I removed it when i realised that there was a huge amount of dust building up. It my first real av project so i was doing all this on the fly really, I learnt so mush so far.
The colours i chosen are black, red/pink and white. i wanted a room that tranfers me to a different place from the rest of the house, my escape room i guess.
The is 6m x 4.5m the roof however is slightly lower than the rest of the house as it built on a garage.
14-04-2009, 12:22 PM
#10 (permalink)
| | Member
Thanks: Gave 23, Got 32 | Re: Gibbs Home Cinema
Looks great, will be following this one.
Like what you did with the AV cupboard
TV - Samsung LE32R87BD | Amp - Onkyo TX-SR606 | B&W 686 Fronts | B&W HTM62 Centre | Yamaha NS-P110 5.1 package (Slowly replacing with B&W 600 range) | PS3 | Xbox 360 | Wii | B&W Zeppelin
14-04-2009, 12:32 PM
#11 (permalink)
| | Member
Thanks: Gave 8, Got 12 | Re: Gibbs Home Cinema Quote:
Originally Posted by gurpswoo1
It didn't matter if there was a line in the middle or didn't look flat as i a great idea to make it better. | What will you do with the line down the middle? I was thinking of something similar, with a sliding cover, but in the end had to think of somethign else. |
14-04-2009, 7:49 PM
#12 (permalink)
| | Member
Hi all i got some more picture uploaded.
The next stage is the floating wall wiring, because the wall is made from breeze blocks i had to use a angle grinder for the cut out, Unfortunently the angle grinder burnt out under load about half way through and plenty of smoke came out.  So i had to do the rest with a chisel no good piece of  .
As you would expect it took alot longer than it was supposed to, oh well all part of the process i guess, but it's no where near as clean cutas before, ohwell here its finished:
I decided to use face plates incase i wanted to remove the speakers anytime and keep a clean finish. i made the cut outs below the main conduit.
I then used dual sheilded power cables connected to a fuse spur. The cable is both foiled and aluminimin braided shielded, its £1 per meter, heres the cable:
The wiring is then fed into centre of floating wall frame.
I also decided to loop a 4 core cable back to the speaker outlets from here, this will connect to two seperate Light circuilts. I then used metal capping for protections and cemented the rest up.
The downlighter were easier to fit.
The front centre one was put on a different switch circuilt to run indepentantly. i also tried a multi coloured blub which cost £1.25:
It gives a very good effect and im please I paid the extra 25p over the standard blub. |
14-04-2009, 9:17 PM
#13 (permalink)
| | Member
The Next stage is subwoofer placment.
I ordered a Bk elec Mon, but i decided to save as much space as possible and i knew how big the sub was, it would have looked ugly sitting by itself. So i decided to put the subwoofer in the wall. on the opposite side of the room. Again i made it as big a possible, but this time the supporting frame was made several times stronger.
The base was made using block board, the roof was going to fall down before this and i even tried to force it down and it didn't move a millimeter. i then had to build the side panel into the cabinet where another temp control fan would be placed and cables for power and sub cable come in.
This side cut out was for the subwoofer heatsink and control dials. the side panels were finished in 10mm MDF as it was more dense. I then fitted the fan using the same transfomer from the other side as will come on at the same time as the amp and projector.
i didn't want any thing coming in through the fan when it was off, so i fitted a metal mess around it then a cooker extrator filter. it was finish off with foam to make sure no air got through the edges, i also used a foam grommet for the power and sub cable.
Not much to look at but is serves it purpose and no one will ever see it.
The cabinet was fitting with acoustic absorbing foam so a local supplier. it's about £25 for 1.25m x 3m 25mm thick.
i don't have the photo of it fitted in the cabinet for some reason, but it was easy. You just need to cut with some good scissors or a knife and stick to walls using double side carpet tap not the cheap stuff from wilkos, you need two to three times as much of it or will fall off.
Thats the sub cabinet contruction complete.
15-04-2009, 6:28 PM
#14 (permalink)
| | Member
Stage 7 - Floating wall Electrics and prep
After 3 weeks of waiting i finally got the RGB lights for the floating wall. however when it arrived i had to pay import tax, whats more some of the lights were damaged but at least it was 3 times cheaper.
Anyway i started to fit the controller unit in the floating wall connecting the supplied power supply to my shielded mains. I had to cut the plug off and connect using a 15amp connector block, amazingly the plug they supplied didn't even include a fuse  , good job i was using a fuse spur.
Now for the hard part, The unit did not come with a RF remote as stated but a Infra red remote. This is a big problem as the controller was going to be behind the floating wall.
So i had to find a infra red extender that ran off 12 volts the same as the RGB lights, this is because the transfomer for all these Infra red units would not fit in the space behind the floating wall. The other big problem was that the infra red unit must be small enough to fit behind the wall as well.
I managed to find one at maplin for £14.99 heres the unit:
I then disassembled it because i needed the infra red diode to be in front of the floating wall.
I cut the three connections to the diode and re soldered then to a 3 longer 3 core wire. i then taped them up in a paint colour and drilled a hole thorugh the unit so i came out without any problems.
I then cut the power connector off the supplied transformer and connected it in parallel to the same 12 volts supply for the RGB lights.
I then placed the unit near the centre with the extending receiver diode pointing down using double sided tap. I then connected the IR extending emitter to the RGB contoller sensor.
Now I needed to connect the the RGB lights in parallel to the two 4 core cables in placed in the wall that were going back to the speaker plates at the front.
I then finished it off by connected them to the terminal block and to the same adaptor as the RGB light strip.
15-04-2009, 7:32 PM
#15 (permalink)
| | Member
Thanks: Gave 19, Got 19 | Re: Gibbs Home Cinema
Very detailed & interesting thread, I will be watching this one evolve. Nice solution for the rf control, will you be able to access it all if something goes bang with minimum disruption?
__________________ My Floating Wall Project - Come and see Panasonic TH-50PZ81B / Denon AVR-3802 / Denon DVD-2800 / PS3 60gb / Wii / Virgin V+ / Kef KHT1005 / Harmony 1000 |
