Originally Posted by Sonylids
I looked there, but typically it has the seating in the middle of the room, which is not possible. Hence why I hope the positioning I have shown on the attachment is suitable.
I have gone for a similar set-up if you look at my floating wall project and my sofa is also against the rear wall. I went for 1.5m apart for my rears so 2 viewers should hear a left & right output without obstruction. Rears on a 7.1 set-up should really be further behind the seating position so as I couldn't do that, I went for in-walls to give me that little bit of extra distance.
Is it suitable???? Well it's not THX perfect but should still give a better sound then basic 5.1
I'm not sure I would go for ceiling speakers for the rears though, they need to be behind you & at ear level. If you have them in the ceiling the sound will envelope you and you will hear from all directions and you will end up with some rear output falling in front of you.
