28-01-2009, 2:41 PM
#1 (permalink)
Thanks: Gave 17, Got 29
New LCD mounted on wall
Hi.
Second time on installing an LCD to a wall. Last time my friends now its my brothers.
So i thought id give pulling wires through the wall a try. It was a daunting task but never the less it got done
So got the cables through and the wall mount up and it looks like this.
In the above pic i have just drilled out a hole near the mount and then a hole at the bottom where the cables will exit. Its so i dont have to use anything like conduit running up the wall.
Got the TV this morning at 7am from Makro ughhh and came home from college and mounted it up.
Only slight problem if someone can help me. There is a big design flaw when it comes to the aerial port. It cant be plugged in as the wall mount tv fixtures are blocking it slightly. I need somesort of bendy adaptor or thin cabling end.
Help? As i havnt ran any Scart cabling for an external freeview box.
28-01-2009, 3:14 PM
#2 (permalink)
Thanks: Gave 17, Got 28
Re: New LCD mounted on wall
Havent seen a bendy adaptor, but I have seen a right angled aerial lead in the B&Q £1 boxes, dont know if thats any help? should only come out a little way, depends how close the bracket is though
28-01-2009, 3:15 PM
#3 (permalink)
Thanks: Gave 901, Got 730
Moved to Home Cinema DIY - more likely to yield you answers.
Blu-ray and DVD Reviewer
The Best Blu-ray and DVD Resource AVForums Movie Reviews Bookmark it now!
My opinions expressed here are not necessarily those of the AV Forums or the associated websites
28-01-2009, 3:57 PM
#4 (permalink)
Thanks: Gave 158, Got 178
I had the same problem with my ultra slim tv mount and used this:
[IMG] [/IMG]
From here: Right-Angled Coax TV Aerial Plug > Maplin
It was still a tight squeeze but fitted where as a normal lead had no chance of fitting in!
Hope that helps
Alz
Optoma HD800X / 84" Screen / Sony Bravia KLV-V40A / Sony HT-IS100 / SkyHD / Harmony One / PS3 / Xbox 360 / Wii / Vaio FZ21E Samsung LE37A656A Black Rose (bedroom) TV.
28-01-2009, 4:24 PM
#5 (permalink)
Well ive got it sorted now. Got a seperate cable and shaved off a bit of the side. It works all fine and dandy now. Looks good though
28-01-2009, 7:21 PM
#6 (permalink)
Thanks: Gave 22, Got 0
(off topic) Ive got them same pc speakers
Toshiba 46ZF355 Samsung BD-P 1500, Toshiba EP35, Kef KHT1005.2,
Onkyo 606, Sky HD, Xbox 360, Wii
Blu Ray 118 HD DVD 165
28-01-2009, 7:23 PM
#7 (permalink)
This is a pic of the updated room.
28-01-2009, 7:25 PM
#8 (permalink)
lolz. Its a small world. Well i had them and then passed them down to my brother when i got 5.1 speakers.
Their not too bad actually for 2.0 speakers and the bass is pretty good lol.
28-01-2009, 7:31 PM
#9 (permalink)
Yeah I have 2 sets quite old now, but still pump out the volume
30-01-2009, 7:48 PM
#10 (permalink)
Thanks: Gave 32, Got 20
nice one  what size tv is that on the wall ?
31-01-2009, 10:50 AM
#11 (permalink)
Thanks: Gave 35, Got 38
What did you use to get the cables through please? Taped to a coat hanger and pushed down to the bottom?
I'm hoping I can do the same but doubt the gap in a dot and dab wall will be big enough to allow a scart plug through..
Samsung LE40M86BD | KEF HTS3001SE | BK XLS200-DF MK2 | Denon AVR-1909 | Sony PS3 PSNID: ruffage | Nintendo Wii | home cinema pics
31-01-2009, 11:31 AM
#12 (permalink)
Originally Posted by flipp_n_phill
you did a good job there mate, looks very clean
Cheers, I would probably been able to do it in 1 day if i had all the equipment at the ready. Looking for a tv was a pain because Comet stopped a deal on a Toshiba 40" 1080P LCD TV.
31-01-2009, 11:32 AM
#13 (permalink)
The TV size is a 42" LCD 1080P screen. Its really good with BluRay and games through PC & PS3
31-01-2009, 11:38 AM
#14 (permalink)
Erm what i did was drilled out two holes in the wall. One at bottom and other at top. and just improvised. I got a nokia charger cable dropped that down until i could see it at the bottom hole. Attached some string onto the end and pulled it up. Fed that through and attached these:
HDMI Cable
DVI-HDMI Cable
Power Extension cable (Plug removed)
Aerial Cable
I added a piece of string to each cable when feeding it through and did them one by one.
I havnt added a scart lead to this set up as everything is going to run in High Deff now except the Aerial lead.
What you could do for the scart is to get phono cables instead.
Hope this helps
Reason: Images break forum rule no. 9
31-01-2009, 12:56 PM
#15 (permalink)
Thanks: Gave 67, Got 17
Same wall mount as mine, very sturdy it is too.
Nice looking room & kit btw.
Al
Living Rm - AS 42" 1080p, 360 Prem., Wii, Vista Ult, Antec V2 Case, P4 3.06, 2GB, 750GB, MCE KB, Pioneer 212, 8800GT 512MB. Cinema Rm - 7.1 QA Setup, 92" screen, Bravia 46", Onkyo 606, 360 Elite, PS3 60GB, Windows 7 Ult, 4096GB, 3TB, ATI 4850. 200mbps Homeplugs throughout.
Cinema Room - All Done!
