Hopefully out there has come across the same problem that I have.
Basically I live in a newish flat, which made from cardboard as far as I can tell, so I have no idea how to ceiling mount my projector screen!
Currently I have manual screen that weighs about 5kg and I hang it as and when I need it from 2 hooks that I have secured into the plasterboard using Heavy Weight fixing from a DIY shop. This has worked for a while but is very annoying as I am not confident enough to leave it up all the time, plus I don't believe I can pull the screen down without putting too much weight on it and just ripping my ceiling down...that would be bad, in addition it also means my very short girlfriend is unable to watch anything on the big screen without me as she simply cant reach to put the screen up!
I had thought of a floor standing screen, no can do though, I use a Sony RHT-G800 Surround Sound Stand for my Audio, saves on wires, so cant have anything that pulls out of a box and 'self erects' in front of it!
So, moving on, I want to get an electric screen, not sure how much they weigh but lets assume 10kg! So, without access from above I am unable to put a batton in the ceiling to attach to. I don't trust simply using the same 2 hooks I currently use and there are no joists anywhere near where I need to mount it, in all honesty I have no idea how this flat doesn't just fall over.
Please get back to me if anyone has successfully encountered and beaten the same problem, pictures would be very helpful!
Mike
