| Mounting LCD to metal stud wall
Yup, another one....
I want to install my 32" lcd to the bedroom wall (new build house). I knew the studs were at 600mm centres and so I found a bracket that just abouts spans two studs. What I didn't realise (despite what the builder's handover notes say) that the studs are metal and not wood. Doh!
I have been given some metal screws - i think they are self drill drywall screws. Would it be safe to fit the bracket with these two of these screws in each metal stud (and washers of course). I would also use some drywall anchors in the plaster board between the studs (poss 3 at top, 2 at bottom of bracket).
Wall is just a single skin of plasterboard. TV is supposed to weight 14kg without the stand, no idea how heavy the bracket is - probably 2kg.
Thanks in advance.
