I have a Sony KDL40W4500 arriving on Tuesday that I plan to wall mount.
I have ordered one of
these mounts.
The wall is a wood and plasterboard stud. Unfortunately the construction of the wall only gives me a single vertical stud to mount the screen on, as you can see in the diagram, and I can build a floating wall in front as there is a trapdoor to the cellar. ( See attached diagram )
My question, perhaps predictably is, should I be OK using the single stud along with some good plasterboard plugs at the corners. The 25kg weight seems quite reasonably to be, but then I've never put a big LCD on a wall before.
Thanks in advance
Attachment 106414
