Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
The Bluray title you consider the best upgrade over DVD paulst10 Blu-ray Movies and TV Programmes 25 20-01-2009 10:47 PM
First Hybrid Blu-ray/DVD Title Announced For Japan DrPepper Movies and TV Programmes On Disc and Downloaded 20 11-01-2009 1:08 PM
got robbed, need an A-Z by title list Fordy Movies and TV Programmes On Disc and Downloaded 11 09-01-2009 11:11 PM
Speaker Wire Soldering Question debunker Speakers 6 07-01-2009 2:25 PM
Old 22-01-2009, 8:53 PM   #1 (permalink)
Thanks: Gave 15, Got 6
soldering irons.
Looking at doing a guitar valve amp kit and am looking at soldering irons.
On a point to point, what wattage should I look for?
Are soldering stations worth it? Maplin do a station for £40 with temp adjustment and I was wondering if this was a good buy
jmsjabb is offline   Reply With Quote
Old 22-01-2009, 11:24 PM   #2 (permalink)
Re: soldering irons.
If you want to work with a normal printed circuit board (one or to sides) a 25 Watt (normal tip) soldering iron will be enough, for boards with surface mount elements, 15 Watt (sharp tip) and for heavy duty (or electrical) 40 Watt or more.
Sorry for my English, I am from El Salvador, Central America!
ricardofmh is offline   Reply With Quote
Old 23-01-2009, 3:36 PM   #3 (permalink)
deckingman's Avatar
Thanks: Gave 29, Got 134
Soldering stations are more for professional users and continuous use. Having said that, £40 for a station is a damm good price. You ought to get a temperautre controlled iron in any case. The higher the wattage, the quicker it will heat up and the sooner you can use it. However, if it isn't temperature controlled then, it would get too hot for fine work. You need to get a fine tip as well. Basically the bigger the iron (wattage) the bigger the tip you can use, but for something like the kit you want to build then a large tip won't be needed. Hope some of that makes sense. Basically, I'd look at something like a 40W, temperature controlled iron with fine tip. Antex are a good make.
deckingman is offline   Reply With Quote
Old 23-01-2009, 5:43 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Its a crap iron i got one and its not been used since its first outing.....
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
irons, soldering
