Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Speaker Recommendations slide_lewy Speakers 8 20-01-2009 6:32 PM
Front speaker posistion johnr2110 Speakers 1 17-01-2009 10:16 PM
Repairing a blown speaker RmsMax Speakers 4 17-01-2009 12:04 AM
What Cable? monkeyshead Satellite TV 4 16-01-2009 10:29 AM
Old 15-01-2009, 7:10 PM   #1 (permalink)
Thanks: Gave 0, Got 4
Rear Speaker cable
The speaker cable for my rear speakers currently just runs up the wall. I'm not happy about this and would like it to run inside the wall. There is space inside the wall to do this, but what im not sure about is how to feed it through. I can make a hole behind the speaker and then at the bottom, but how do I get the cable to go through and meet up with the holes?
Woody26 is offline   Reply With Quote
Old 15-01-2009, 7:22 PM   #2 (permalink)
Shoka's Avatar
Thanks: Gave 215, Got 135
Re: Rear Speaker cable
I could be wrong on this but... you will most likely have to rout a channel in the wall bang a bit of trunking in, and then plaster over it.
Shoka is offline   Reply With Quote
Old 15-01-2009, 7:26 PM   #3 (permalink)
It depends on if there is a firebreak in the wall, and if its insulated (outside wall). if there is no firebreak (usually two story wall)then you can make a hole at the speaker and another directly at the top of the base board and tie the wire to a weight (heavy washer, bolt, etc...) drop it in the hold and fish it out the bottom with a bent coathanger...you can then fill the holes with caulk and youll never see them, except way up close. now keep in mind there are other ways to do it but this one worked for me, and the install looked pretty clean with minimal sheetrock work.
CYCLONE53 is offline   Reply With Quote
Old 16-01-2009, 2:38 PM   #4 (permalink)
I know there is a gap behind the plasterboard to the breeze blocks so I'm hoping I could drop it down in the gap
Old 17-01-2009, 7:31 AM   #5 (permalink)
Thanks: Gave 6, Got 6
Hi, I've just done this for my speakers and it works for both dab/board and framework walls. Make a 7mm hole just above the skirt and another at the speaker position. Lower a small nut tied to some string into the top hole and guide it down using a magnet (a decent magnet will still attract the nut through the plaster board). That way you can move it around plaster dabs if necessary. If you come to a horizontal noggin, then you'll need to drill a hole just above and below the noggin and cut out the plaster in between, bring it out and then back in and down to exit at the skirt. Tie your speaker cable securely to the string keeping the joint as flat as possible (I looped and taped it with insulation tape) and gently pull the string from the top taking the cable with it. The plaster over the noggin can easily be filled and painted when the cable is in position. Good Luck.
Hitachi 42pd7200,Panasonic TH50PZ70, Sky HD, PS3, Panasonic DMP-BD35, Wii, Onkyo TX SR876, 7.1 MA R90 AV12, Ipod Touch, Dell 1525
Andyduz is offline   Reply With Quote
Old 17-01-2009, 10:03 AM   #6 (permalink)
Andy, what an excellent idea! I will try that, thanks very much
cable, rear, speaker
