Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Starting The Gym Advice Needed? delboyuk2005uk General Chat 94 24-01-2009 1:10 PM
Do you watch the End Credits to a Movie? (Poll) Pincho Paxton Movies and The Cinema 24 18-01-2009 2:27 AM
Find the speed camera leej General Chat 16 15-01-2009 7:44 PM
Old 15-01-2009, 3:58 PM   #1 (permalink)
The floating wall Begins
Afternoon All,
After reading some of the posts here and wanting to put my LCD on the wall i thought i would do a floating wall so here goes first on the list was to strip the walls. the next thing is to build the frame for the wall which will be started tomorrow and then fixing the LCD wall mount
ImageShack - Image Hosting :: 15012009205jy9.jpg
Question's
1)What screws do you recommend to use on the frame?
2)What bolts would you recommend for fixing the LCD mount to the wall as the boltss that came with the mount i wouldn't feel safe using them?
I look forward to reading your advice.
Many Thanks
Matt
M@ty-C is offline   Reply With Quote
Old 15-01-2009, 5:11 PM   #2 (permalink)
Grangey.'s Avatar
Thanks: Gave 42, Got 84
Re: The floating wall Begins
Originally Posted by M@ty-C View Post
Afternoon All,
Question's
Many Thanks
Matt
1) what type of wall are you fixing too? If brick, I used 90mm long ones cant remember what theyr by but theyr not huge, but hold it too the wall very well. But bear in mind I am doing mine slightly differently (see my thread)
2) Coach bolts do a great job holding mine, only using 8 i think and its solid as a rock. what size if your tv?
Sony KDL40W2000, Onkyo TXSR875B, SONY PS3, Xbox 360, Sky HD, Wii, B&W 603's, AE 107C, and some cheaper speakers to compleate the 7.1 Speaker setup.
Grangey. is offline   Reply With Quote
Old 16-01-2009, 1:28 PM   #3 (permalink)
Cheers for your reply grangey i will be fixing the frame to a brick wall, and my telly is 40" LCD mate. A bloke at work told me to use rawl bolts for my mount but thanks for your advice on the coach bolts on long are these? i'm liking you guide is your floating wall done yet? i'm hoping to complete min by next weekend so i will post any updates
Old 16-01-2009, 4:50 PM   #4 (permalink)
Re: The floating wall Begins updates
just a little update have bought some anchor bolts for the LCD mount and ordered my timber for the frame to be delievered tomorrow
Anchor Bolts
ImageShack - Image Hosting :: 16012009208fd9.jpg
Anchor Bolt
ImageShack - Image Hosting :: 16012009211qu9.jpg
I am still a little unsure about these anyone else used these just to put my mind at rest. Hopefully more updates tomorrow with the frame going up.
Matt
Old 16-01-2009, 8:09 PM   #5 (permalink)
Grangey.'s Avatar
they certainly look like theyd do the job! the thing is, alot of people (myself included) are simply over precausious with fixings for a wall mount. You dont even need as heavy duty as that unless you regularly sit on your tv...?! So im sure theyl do you fine.
My wall finally went up properly today! Iv now just gotta do a crap load of sanding ready for prep and paint!
Old 22-01-2009, 2:39 PM   #6 (permalink)
Afternoon all,
Just a little update the timber was delieverd monday for the fame so wednesday i could make a start on the frame i just need to add somemore timber to make it a little more secure. Then on friday i will be mounting the frame and LCD mount to the wall. Just a quick question the rope lights from tlc direct do i need to buy the mains connection kit aswell?
Old 22-01-2009, 5:46 PM   #7 (permalink)
Grangey.'s Avatar
Yes you do
On a side note, if you click the image icon when posting a response with pictures and enter the links like you've posted above in the box that pops up, it gives us bigger pictures to look at so saves us having a new window open to see your pics imageshack
Old 22-01-2009, 6:28 PM   #8 (permalink)
Thanks: Gave 6, Got 6
guys on this site really need to chill out a bit with their fixings, we use rawbolts and the like to fit things like floor joists to walls and in roofing etc. having said that overkill is not a bad thing so go with what ever you are happy with.
Andy
andy900uk is offline   Reply With Quote
Old 23-01-2009, 2:19 AM   #9 (permalink)
Cheers for your reply grangey. i know whereyour coming from andy900uk i just want to be able to sleep at night knowing its not going to be on the floor. any hopefully more pictures later today.
Matt
Old 25-01-2009, 9:09 AM   #10 (permalink)
Just an update really frame is attached to the wall and so is the LCD wall mount here are the picutures, sorry grangey but for some reason it won't let me make them bigger on the post
Don't worrie the wood isint proping anything up lol. i had forgot to mention that this was a budget build so here is what i've spent so far.
LCD Mount £33 Ebay
8ft 2x1 x 7 £15
8ft x 4ft x 2 £35
Accessories (Screws and bolts) £12
Thanks for reading
Matt
Old 25-01-2009, 11:55 AM   #11 (permalink)
Grangey.'s Avatar
here you go bud. You're right, its Image shack that are making things awquard, but if you want to, open up the links bringing the picture into a different window... Right click on the PICTURE itself... go to properties... then copy the address under "Location". Then edit your initial post and click the image tap (yellow square with what looks like 2 mountins in it), paste the address in there... and there you go
Progress looks good! When are you hoping to be compleated?
Old 25-01-2009, 2:19 PM   #12 (permalink)
well i did want it finished this weekend but had other things to do so i am hoping next weekend it will be finished just got to order the rope lights later today. Question we are wallpapering the living room and the wall that the floating wall is on to i just want to know if we can wallpaper on the MDF? and if so would i have to sand the MDF?
Many Thanks
Matt
Old 28-01-2009, 11:37 AM   #13 (permalink)
Just a little update ordered my rope lights sunday and they arrived yesturday so heres a couple of pictures Grangey it won't even let me do it that way maybe i have to make a number of post before it will let me i just don't know
Day View Night View
Again sorry for the small pictures i'll have to find another image hosting website comments welcome.
Many Thanks
Matt
Old 28-01-2009, 12:33 PM   #14 (permalink)
Grangey.'s Avatar
Looks good mate!
Old 29-01-2009, 10:28 AM   #15 (permalink)
Another little update have just ordered SKY HD for £79 bargin me thinks just waiting now for a installaition date.
Matt
begins, floating, wall
