Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
No access to Hard drive AGAIN!!! tenpintaker Sky and Sky+ 13 14-01-2009 3:35 PM
would like to upgrade to sky+hd garycurry Sky HD 6 13-01-2009 5:06 PM
Pinnacle 3010ix causing vista media centre to freeze bnet Graphics Cards, TV Tuners and Webcams 3 13-01-2009 9:36 AM
BEWARE when buying CHEAP HDMI cables off EBAY!!! Jonathan Fletch Camcorders and Video Editing 15 12-01-2009 5:14 PM
Speaker Isolation Plinths - Where to get this one?? Lewisimo Speakers 3 12-01-2009 4:17 PM
Old 14-01-2009, 3:22 PM   #16 (permalink)
Thanks: Gave 16, Got 105
Re: Easiest wat to chase speaker cables
Chasing a wall and filling and painting is far easier, quicker and cheaper than using mdf
John.
27neth is offline   Reply With Quote
Old 14-01-2009, 5:12 PM   #17 (permalink)
Thanks: Gave 67, Got 77
John.
True, especially for this size job. Plus MDF is a nightmere to paint and is nasty stuff to work with..
Spiderkid is offline   Reply With Quote
Old 04-06-2009, 11:30 AM   #18 (permalink)
Thanks: Gave 6, Got 9
Originally Posted by mxs View Post
Sorry mate! I would have opted for a sheet of MDF.
All that faffing around chasing walls when you could have hid the wiring behind a piece of board
With respect they usually all look crap and when I see them I just instantly thing "too pussy to drill"
If you have just moved into somewhere, hire a wall chaser and chase all your lines then plaster as it's the easiest way but creates a lot of mess, otherwise the sds drill or hammer and chisel works great.
APatel is offline   Reply With Quote
Old 04-06-2009, 11:41 AM   #19 (permalink)
Greg's Avatar
Thanks: Gave 99, Got 752
Disagree. Chasing out and then filling and painting is a piece of cake.
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Science created him. Now Chuck Norris must destroy him!
Greg is offline   Reply With Quote
Old 27-08-2009, 7:40 AM   #20 (permalink)
Hi if anyone is still subscribing, I think that looks good I want to mount my tv on the wall, I can get the builders to put a flush power socket on the wall behind the screen and a aerial socket but I'd like to be able to put a feed cable from a dvd machine and maybe a recorder up the wall as well They will be housed in a unit / cupboard sat on the floor ... obviously, at some time (probably the day after they're fitted) the dvd player will break so I feel the cables need to be feedable / replaceable, maybe up some trunking of some sort, obviously the 'chasing' has to be bigger and deeper but I wouldn't imagine that's a big problem .... anyone any advice please ? Regards Roger
rogertb is offline   Reply With Quote
Old 27-08-2009, 5:14 PM   #21 (permalink)
Thanks: Gave 11, Got 7
Originally Posted by Sandman View Post
Well I did it tonight, I started with hammer and chissel and the plaster on the wall was so easy to dig into I replaced the hammer with a sharp screwdriver. Worked a treat! I have placed the cables into the groove and plastered over the top of them. Here is the finished article (will paint tomorrow).
Sorry to be picky... But you aren't going to leave that 5cm or so of speaker wire showing are you?
Super Andy H is offline   Reply With Quote
Old 27-08-2009, 7:47 PM   #22 (permalink)
Thanks: Gave 138, Got 36
Agree - you should have gone up 5mm more, and run the cable 'through' the back of the bracket.... thats how i did my eggs when i had them....
DOH..
Arcam DV135, FMJ AV9, FMJ P7, B&W 704s, HMT7 and DS7s; Pioneer 506, Sky HD, Xbox 360, PS3, Wii, Sonos ZP80 & ZP100 - want a projector, but need a bigger room first
kevshed is offline   Reply With Quote
Old 27-08-2009, 9:01 PM   #23 (permalink)
DOH..
Or just drop the speakers a little. It's not too late.
Old 27-08-2009, 10:19 PM   #24 (permalink)
touche
Old 29-08-2009, 9:02 AM   #25 (permalink)
jagdeepp's Avatar
Thanks: Gave 174, Got 100
I bought a wall chaser from Aldi of all places. Cost me £29. One of my best all time purchases. The only downside was the level of dust!! I was however left with PERFECT cuts on each occasion.
For your project however i would've done the same as you. It would have been way to much hassle to clean up after.
My Set up: Sony Panny PT-AX100 HD Projector, 2.2 metre HCSV electric screen, Arcam AVR350 amp, HTPC's with 1 TB, Monitor Audio RS6 5.0, BK Monolith, Nintendo Wii, Snazio 1310, Xbox 360,
My Home Cinema Lounge & Home makeover
jagdeepp is offline   Reply With Quote
Old 29-08-2009, 8:06 PM   #26 (permalink)
Sanders79's Avatar
Thanks: Gave 65, Got 28
If you want to be able to pull out old cables or introduce new ones then you'll need to sink some kind of trunking into the wall. Lots of people use round plastic pipe/conduit for smaller cables like speaker cable. For scart leads the main issue is the big plug - you can either sink some really big trunking into the wall (like I did! ) or you can get scart leads with removeable plugs (like this one - about two thirds down the page) that you can feed through a smaller conduit.
In my install I sunk some rectangular profile trunking into the wall, which measures 100 mm x 50 mm. The front pannel slides on and off, so I was able to access the inside and screw it firmly in place before sliding back the cover ready for plastering over. It means I have enough space for any more cables I might need to add between TV and av cabinet in the future
I did it all with an angle grinder (a really big one) and a hammer & chisel. I had the luxury of being able to work on the house for three months before we finally moved in, so the massive mess it caused was not a problem... there is no way I would do it in an occupied building though.
Yamaha RXV-1900 with YDS12 iPod dock, MA Radius R90 speaker package with RSW12 sub, Pioneer BDP-320, Sony KDL-40V2000, Sony RDR-HXD970, Sky+, Wii, Harmony 1000, various cables from Mark Grant, Ixos, QED and Van Damme.
Sanders79 is offline   Reply With Quote
Old 29-08-2009, 8:07 PM   #27 (permalink)
Sanders79's Avatar
£29? Sounds like a bargain! Is it one with discs or one of those you put on a drill?
Old 29-08-2009, 11:42 PM   #28 (permalink)
jagdeepp's Avatar
Its the one with the discs mate. You really cant go wrong. Watch out for the dust though...
Old 29-08-2009, 11:43 PM   #29 (permalink)
Sanders79's Avatar
Haha! Been there, done that, shouldn't need to do it on such a large scale ever again with any luck either!
cables, chase, easiest, speaker, wat
