Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Mounting a Plasma in a wall PSM1 Plasma Televisions 5 06-01-2009 1:42 PM
Mounting My Plasma - Wall Chasing Advice RaceyBoy Home Cinema DIY 5 06-01-2009 12:08 PM
All in One Sat/TV/Tel Wall Socket - Not Distribution ones! falken_gt4 Satellite TV 7 05-01-2009 10:34 PM
Old 05-01-2009, 11:51 AM   #1 (permalink)
Thanks: Gave 100, Got 47
Wall mounting - Dot and Dab
I've been reading various threads about wall mounting TV's to dot and dab plasterboard walls and people have said to cut out the plasterboard where the mount is going and mount directly to the blocks behind.
Would just bolting a bracket through the plasterboard and into the blocks make any difference at all? Or will there be some strain on the plasterboard still hence why people have said to cut out the plasterboard?
The reason i ask this is when fixing a frame for a floating wall you would fix through the plasterboard into the brickwork behind?
Gary
thelegendofyrag is offline   Reply With Quote
Old 05-01-2009, 6:02 PM   #2 (permalink)
Thanks: Gave 28, Got 7
Re: Wall mounting - Dot and Dab
Hi mate,
the reason i didn't just mount on the plasterboard is if you do it would be very easy to over tighten the bolts and bend/crack the plasterboard. when i did mine i marked on the plasterboard where the holes needed to be and then using a hole saw cut a 20mm diameter hole through to the block work, i then cut some spacers using an old broom handle that came flush to the plasterboard surface and drilled a hole through the middle, i put the projecting anchor bolts into the block, put the spacers over and then bolted on the mount.
dave
Lounge panasonic 50pz70, optoma hd700x, 92" screen, sky hd, ps3, wii, toshiba ep30 hddvd, sony str-dg910, tannoy sfx 5.1Dinning room panasonic 32lxd70, shuttle pc, athlon dual core 5600,LG blu ray/hddvd drive, yamaha av63 (rx-v363 nsp110)Bedroom sony 32t3000, sky plus, yamaha av63 (rx-v363 nsp110)
Torn is offline   Reply With Quote
Old 06-01-2009, 9:52 AM   #3 (permalink)
Ok mate thanks for the tip. I'm wanting my screen as level to the new wall as possible so after thinking about it cutting some plasterboard out could be a good idea. Just don't like the sound of doing it!!!
Old 06-01-2009, 11:49 AM   #4 (permalink)
Thanks: Gave 369, Got 63
I never sunk mine in, but wish i did now, but it's fine has been for over 2 years - For cutting the plaster board there is a plasterboard saw you can get for a few quid, which is worth it as it makes the job a lot easier!
Cinema room spec: [eyes] Planar PD7010 - [ears] Samsung HTZ310R - [Heart] PS3
My Cinema Room Build...
deefadog is offline   Reply With Quote
Old 06-01-2009, 12:11 PM   #5 (permalink)
Thanks: Gave 36, Got 176
Some info here http://www.avforums.com/forums/lcd-b...ml#post8479365
A Plasma n Stuff
oldnewbie is offline   Reply With Quote
Old 06-01-2009, 12:28 PM   #6 (permalink)
thanks for the info guys. One thing im concerned about sinking the screen into the plasterboard directly onto the block behind would there be much dust and dirt in there that would get into my tv's vents?
Old 06-01-2009, 1:10 PM   #7 (permalink)
If like my walls you will have around half an inch gap between brick and PB, i'd just fill the edges up with plaster so the cut out is sealed if you get me. Does not have to be a top job as it will not be seen!
Old 06-01-2009, 1:19 PM   #8 (permalink)
Good idea as i was intending to use plasterboard for the new wall anyway with a skim of plaster over the top i can do the gaps at the same time!
One question regarding the frame for the new wall, do people leave a gap in it somewhere so the wires can be sent down behind the plaster/mdf to all the equipment?
Old 21-01-2009, 12:44 AM   #9 (permalink)
Thanks: Gave 10, Got 7
No need for any of that
RIGIFIX bolts solve this issue and are installed in minutes and cost less than £10 for 6!
See here
http://www.avforums.com/forums/custo...-mounting.html
Panasonic TH50PZ80B & Panasonic SC-HT840, Sanyo PLC-XW15 projector & 1.75m screen; Toshiba 32ZP48 & Panasonic SC-HT70 5 disc DVD changer.
MAD ANDY is offline   Reply With Quote
Old 21-01-2009, 2:47 PM   #10 (permalink)
Andy i want the back of the screen flush with the plasterboard hence why im mounting to the brick
My AV Set-up
Old 23-01-2009, 5:45 PM   #11 (permalink)
ah, thought you were only on about doing that because thats what you had been told - just bear in mind the issue getting cables to it, the heat in the gap and the big ugly hole should you ever move it
dab, dot, mounting, wall
