3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Set Up Help - Sky to 1909 IanTag Denon Owners' Forum 10 07-01-2009 12:14 AM
AV shops in the UK that deliver to the EU grega Speakers 11 05-01-2009 3:06 PM
Some help with playing TrueHD on the 'Yamaha Dspax761' please Dave_L AV Amplifiers and Receivers 13 05-01-2009 12:54 PM
Can anyone help please: BK XLS200, XLS300 or SVS SB12+ whimsical Subwoofers and Tactile Transducers 9 04-01-2009 10:18 PM
MA Silver + Plasma = stand help SteveTDCI AV Stands, Cabinets, Seating and Furniture 0 03-01-2009 12:57 PM
Old 03-01-2009, 1:08 PM   #1 (permalink)
abdus's Avatar
Thanks: Gave 344, Got 136
AV cabinet and ventialtion/cooling help
just got a small av cabinet.
I need some input regarding ventilation/cooling. I'm placing a sony amp and a ps3 in it but they juts fit in.
is this enough space for the amp and PS3 to cool?
Or are the sides too close to the cabinet?
I will be making larger holes at the back,for cabling also and to aid cooling.
Any help appreciated. Thanks
abdus is online now   Reply With Quote
Old 03-01-2009, 3:41 PM   #2 (permalink)
Grangey.'s Avatar
Thanks: Gave 41, Got 84
Re: AV cabinet and ventialtion/cooling help
switch their positions and you should be fine, amp needs significantly more ventialtion than the ps3, or simply remove the shelf above the amp.
Sony KDL40W2000, Onkyo TXSR875B, SONY PS3, Xbox 360, Sky HD, Wii, B&W 603's, AE 107C, and some cheaper speakers to compleate the 7.1 Speaker setup.
Grangey. is online now   Reply With Quote
Old 03-01-2009, 3:43 PM   #3 (permalink)
Grangey.'s Avatar
oh and to be safe I would stand your 360 up as it ventilates from the SIDE. so confining it could cause you problems, where as im not sure on the ps3 but I would check if I were you
abdus (03-01-2009)
Old 03-01-2009, 4:43 PM   #4 (permalink)
Thanks: Gave 7, Got 36
abdus i would not be happy to use em like that,your ps3 as air vents on the right hand side as well,which are now blocked,well im guessing they are air vents,thats what they look like to me on mine,
xbox is well known for over heating,and i think you will be helping it more so,like grangey_civicsr said,would be better off standing it up,unless thats not what you want, ive put some blocks of wood under my xbox to help with ventilation as well,as theres vents there,as it sits so close to floor level when on its own little rubber pads thats on as standard imho
wese007 is offline   Reply With Quote
abdus (03-01-2009)
Old 03-01-2009, 5:37 PM   #5 (permalink)
abdus's Avatar
I've moved the PS3 to the middle section. (where the amp is), put the amp on top of the cabinet (doesn't look that bad)
Not to forget there will be an HD DVD player to go on the shelves above the amp (as it stands now in the pics above)
Regarding the xbox, the cabinet isn't high enough to put it standing up. So i guess raising it on blocks would be the better solution.
virgin box will go in place where the PS3 is now.
I will post some more pics later. Thanks for your replies. Appreciate it
cabinet, ventialtion or cooling
